Home > Maintenance & Modifications > Rear body mounts stuck! Pictures
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hi all- using this unusual time of being locked at home to work on the defender and make the move to stainless with the nakatanenga kit. Really struggling with the rear body mount Torx screws- managed to shift a few but the others are now stuck half way out- tried everything from blowtorch to WD40 in the threads but no luck. Managed to remove a couple and switch them to stainless as you can see but the others aren’t going anywhere.
Also regarding the rear hinges mine have started to fade a little but not sure if I should repaint them or changes them- they don’t seem to have rusted yet!
I’m really new to working on cars in general so any advice on the best thing to do would be greatly appreciated, thanks!
Post #822014 29th Mar 2020 12:23pm
90 Dreamer
A better penetrating fluid and try winding them in and then back out, repeated times........
Post #822018 29th Mar 2020 12:33pm
MarcusM
Thanks that’s really helpful- in your experience what’s the best penetrating fluid you have found?
Post #822024 29th Mar 2020 12:49pm
90 Dreamer
We use Bulldog BDX at work but not sure how easily available it is........
The likes of Plus Gas and sure there are others
Post #822027 29th Mar 2020 12:51pm
MarcusM
Brilliant thanks Very Happy
Post #822034 29th Mar 2020 1:02pm
gilarion
Thumbs Up For Plus Gas For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #822049 29th Mar 2020 2:48pm
Bluest
I’ve had some good success with WD40 specific penetrating spray. 2007 110 TDCi Station Wagon XS
Post #822064 29th Mar 2020 3:44pm
Plus Gas for me.
Post #822072 29th Mar 2020 4:02pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
How about applying copper grease to them before winding them back in and out again?
Post #822074 29th Mar 2020 4:05pm
MarcusM
Thanks all- will look in to getting some better penetrator and great idea about putting the copper grease in to the thread Scott- will try it and let you know how I get on. So much of the basics to learn!
Post #822081 29th Mar 2020 4:38pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Marcus.
As a retired mechanical engineer I can only offer the following.
Its the rust/rubbish building up on the treads if you can get a wire brush or an old tooth brush ( if you have an old spare wire brush cut it down to fit) in to remove the build up when you screw them back in then spray them and wind them out until you get some resistance, don't try and force them at this point as you risk causing damage to the threads. Also spray a bit of your release agent on the threads you have screwed out before screwing it back in. Take your time as you may only get one more thread out each time and make sure you seat the Torx sockets square to the bolt to prevent damaging it. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #822210 30th Mar 2020 9:57am
MarcusM
ARC99 thanks so much for your advice- sounds like a good plan- I think I was trying to rush the whole thing too much but will spend some time working on each one as you say.
Post #822252 30th Mar 2020 1:21pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
I am in the process of doing this as well one left to remove, agree with ARC take your time winding in and out cleaning threads to remove All the crud and plenty of wd40 or the like and you will get them. Rush and you will shear them I know as I did this to the first one and had to drill out and retap the tread. Also isolate the stainless steel washers from the aluminium body work with nylon washers behind them to help prevent dissimilar metal corrosion occurring Andy
Defender 90
Defender 110 XS
Cupra 290
Post #822412 30th Mar 2020 10:09pm
MarcusM
Thanks for the tips Oakseywick - great time right now to be working on this!
Post #822450 31st Mar 2020 9:15am
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Also make sure you use a good quality torx bit it does make a difference Thumbs Up Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #822477 31st Mar 2020 11:52am
