Home > Maintenance & Modifications > Rear body mounts stuck! Pictures |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
A better penetrating fluid and try winding them in and then back out, repeated times........
29th Mar 2020 12:33pm |
MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101 |
Thanks that’s really helpful- in your experience what’s the best penetrating fluid you have found?
29th Mar 2020 12:49pm |
We use Bulldog BDX at work but not sure how easily available it is........
The likes of Plus Gas and sure there are others |
29th Mar 2020 12:51pm |
Brilliant thanks
29th Mar 2020 1:02pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
For Plus Gas For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
29th Mar 2020 2:48pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I’ve had some good success with WD40 specific penetrating spray. 2007 110 TDCi Station Wagon XS
29th Mar 2020 3:44pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16923 |
Plus Gas for me.
29th Mar 2020 4:02pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 644 |
How about applying copper grease to them before winding them back in and out again?
29th Mar 2020 4:05pm |
Thanks all- will look in to getting some better penetrator and great idea about putting the copper grease in to the thread Scott- will try it and let you know how I get on. So much of the basics to learn!
29th Mar 2020 4:38pm |
Marcus.
As a retired mechanical engineer I can only offer the following. Its the rust/rubbish building up on the treads if you can get a wire brush or an old tooth brush ( if you have an old spare wire brush cut it down to fit) in to remove the build up when you screw them back in then spray them and wind them out until you get some resistance, don't try and force them at this point as you risk causing damage to the threads. Also spray a bit of your release agent on the threads you have screwed out before screwing it back in. Take your time as you may only get one more thread out each time and make sure you seat the Torx sockets square to the bolt to prevent damaging it. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
30th Mar 2020 9:57am |
ARC99 thanks so much for your advice- sounds like a good plan- I think I was trying to rush the whole thing too much but will spend some time working on each one as you say.
30th Mar 2020 1:21pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
I am in the process of doing this as well one left to remove, agree with ARC take your time winding in and out cleaning threads to remove All the crud and plenty of wd40 or the like and you will get them. Rush and you will shear them I know as I did this to the first one and had to drill out and retap the tread. Also isolate the stainless steel washers from the aluminium body work with nylon washers behind them to help prevent dissimilar metal corrosion occurring Andy
Defender 90 Defender 110 XS Cupra 290 |
30th Mar 2020 10:09pm |
Thanks for the tips Oakseywick - great time right now to be working on this!
31st Mar 2020 9:15am |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 726 |
Also make sure you use a good quality torx bit it does make a difference Formerly mao99999
16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
31st Mar 2020 11:52am |
