Home > Puma (Tdci) > Another output shaft.....
Page 16 of 18 <123 ... 15 161718>
DSC-off
Hi Nige,
Hopefully someone will give you an answer on the amount of play on a brand new shaft. I haven't seen one go together, so can't comment on that.
It was very interesting to see yours come apart in the video, thanks for posting.
It all looked very clean in there, with traces of grease and no powdery rust in the coupling.
Most of the pictures of failed and badly worn shafts I've seen on here show both rust and dust, and/or shiney worn splines.
Yours looks to be in perfect condition to me, but as said, I haven't done one myself.
Before I saw the video, I would have said replace it just to be safe, however seeing how clean it is, I think I'd be tempted to give it a good coat of grease and put it back together.
Waiting for more opinions on this.
Cheers, Jason Thumbs Up
Ps, nice Mustang!
Post #813419 3rd Feb 2020 7:48pm
Jem_90
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
Yup same here, 2.4 USW 2011, 87k miles. Let go all of a sudden whilst doing a three point turn. 🤬
Post #814922 13th Feb 2020 1:07pm
Looking at the wear in the pictures above, it looks to me as though that was not properly engaged with the spring ring secured in the groove. It's hard to be sure from the photos though.
I do think that improper assembly may be another factor in the failures.
Post #814966 13th Feb 2020 5:01pm
MK
Probably one of the worse I have seen! Puma 110" SW
Post #815087 14th Feb 2020 2:39pm
Fat Cog
JLR customer relations...any comment? Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #815089 14th Feb 2020 2:47pm
Caterham
Yeah. 'they all do that sir'
Post #815097 14th Feb 2020 3:19pm
"Problem? What problem? There is no problem with the output adaptor shaft."
Post #815114 14th Feb 2020 5:15pm
Caterham
just realised. LR are ahead of the game with this eco friendly stuff.
I hadn't realised the drive train was designed to be recycled - you can put it in your sandwich once it fails hence why they made it of cheese. Laughing
Post #815117 14th Feb 2020 5:27pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
I think you'll find ther output shaft is made of cheesecake base, it's the 2.2 oil pumps that were made of cheese. Funny, because this all goes nicely with the jacobs cream cracker clutch.
As for being friendly to the enviroment, the chassis begins returning to earth from day one. Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #815121 14th Feb 2020 5:48pm
Jem_90
I'm going to re purpose it as a £700 burr pepper grinder ! Laughing
Post #815123 14th Feb 2020 5:54pm
Caterham
and I thought the clutches were digestives by McVites - also go well with oil pumps / cheese Thumbs Up
Post #815124 14th Feb 2020 5:55pm
Quite
https://www.defender2.net/forum/topic36916.html
Post #815144 14th Feb 2020 7:36pm
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
Mine is TDCI 2012 covered almost 112 000 km. Since new, it has a backlash. Decided to go for Lof clutch and Ashcroft output shaft. After the change Defender drives completely different. There is no backlash and it drives wonderful.
Clust had loose springs and here are the pictures of the original output shaft
Although it does splines look good this I think this shaft is over.
Anyway, this will be my last Land Rover \ Range Rover. I am not going to sell it but I will not buy the new s...t which most probably has the same problems. Next time I will take Japanise or US offroader.
Post #815153 14th Feb 2020 8:07pm
That definitely looks like it's spent its life completely dry with no lube.
Probably like that from the factory. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #815156 14th Feb 2020 8:24pm
sollner11
Germany 2016 Defender 110 Puma 2.2 SW Keswick Green
I was curious.
The shaft ( Date of Manufacture = 15.08.2015) was greased at the LR factory.
27.400 miles
TD4 2.2 110SW
now I'm calmed down Wink
Post #817745 1st Mar 2020 6:36pm
