Home > Puma (Tdci) > Lock Diff |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7732 |
just watched the video
it depends how you are driving it to is it reacting right. when it gets into the cross axle and starts to spin a wheel you should then accelerate and keep accelerating until it moves fwd. if you were doing that and it rocked back as in the first couple of attempts all 3 bumps then its not right. What is more likely is that you got cross axled, started to accelerate, it moved fwd a little, you backed off, TC slowed down a bit, it rolled back, you accelerated again and it kept going like that a couple of times before you backed off then tried again with more momentum. When it drives off the last bump for the 2nd time is how it should react all the time. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Mar 2009 9:49pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I questioned your diff lock because only 1 wheel appeared to be turning on the first hump (half way through the clip). That said, I can't really see the other side of the car so I guess you were properly x-axle'd at points. Looking at it again, I can see that is the case on the second hump. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
4th Mar 2009 11:43pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
You are correct - I did back off the gas as I would in the series to try regaintraction. Was my first week of ownership back then.
I have since on many occasions had the system kick in but it does seem still allow a lot of slip before it actually breaks the wheel. I say this looking out the window of the drivers side so I can't tell if the opposite is slipping at the same rate. Puma 110 - gone Series III 1973 - going strong |
5th Mar 2009 6:30am |
