Home > Td5 > weird leak |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2088 |
What side?
Pics would help Instagram @defender_ventures Empire Tuning - Agent |
11th Aug 2019 5:00pm |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 |
Click image to enlarge Click image to enlarge Click image to enlarge |
11th Aug 2019 5:01pm |
sorry, i uploaded but forgot to actually post them. i just did. its the right side of the engine compartment. |
11th Aug 2019 5:02pm |
Most likely spilling for the PAS reservoir when on an incline or very hot. It happens. The breather hole for the PAS is at the back and does spill there Instagram @defender_ventures
11th Aug 2019 5:04pm |
this hole? its pointing directly at the front bumper and doesn't appear to be leaking. or is there another vent hole?
11th Aug 2019 5:38pm |
Is it oil, diesel or coolant? |
11th Aug 2019 5:48pm |
That is the one im on about yes. Unsure if there are two
Could be a leak from the pas anyway, id check Instagram @defender_ventures Empire Tuning - Agent |
11th Aug 2019 5:51pm |
i can't tell. its is a bit slick to the touch but i can't detect an odor. i clean the area up and it comes back in a day. everything on the side of the motor seems dry.
11th Aug 2019 5:55pm |
i'll clean and wrap the res in a rag to see if it comes back.
11th Aug 2019 5:56pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
There is a hp diesel hose along the engine runs from the back to the front. I had a leak there last month. But as it is a 4 bar pressure line I think it would be more visible. At least mine left some some traces for about 10 km that you still could follow a few days later. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Aug 2019 6:09pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5436 |
Have you checked the pipework from the engine breather.
12th Aug 2019 9:33pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2202 |
If it is coolant, check the fuel cooler under the inlet manifold. Mine used to leak only when the engine was warm. If it is PAS fluid, check the union at the front of the engine near the front most inlet manifold bolt. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
12th Aug 2019 9:44pm |
