![]() | Home > Td5 > weird leak |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2091 ![]() ![]() |
What side?
Pics would help Instagram @defender_ventures Empire Tuning - Agent |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
sorry, i uploaded but forgot to actually post them. i just did. its the right side of the engine compartment. |
Most likely spilling for the PAS reservoir when on an incline or very hot. It happens. The breather hole for the PAS is at the back and does spill there Instagram @defender_ventures
this hole? its pointing directly at the front bumper and doesn't appear to be leaking. or is there another vent hole?
Is it oil, diesel or coolant? |
That is the one im on about yes. Unsure if there are two
Could be a leak from the pas anyway, id check Instagram @defender_ventures Empire Tuning - Agent |
i can't tell. its is a bit slick to the touch but i can't detect an odor. i clean the area up and it comes back in a day. everything on the side of the motor seems dry.
i'll clean and wrap the res in a rag to see if it comes back.
There is a hp diesel hose along the engine runs from the back to the front. I had a leak there last month. But as it is a 4 bar pressure line I think it would be more visible. At least mine left some some traces for about 10 km that you still could follow a few days later.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5455 ![]() ![]() |
Have you checked the pipework from the engine breather.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2210 ![]() ![]() ![]() |
If it is coolant, check the fuel cooler under the inlet manifold. Mine used to leak only when the engine was warm. If it is PAS fluid, check the union at the front of the engine near the front most inlet manifold bolt. 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
