Home > Maintenance & Modifications > flushing a diff?
donmacn
flushing a diff?
Tried doing a search, but it doesn't seem to be working for me today. (I get a page saying something about unacceptable response...)
The other day, after a long run where I was hearing a howling noise, I cracked open the filler plug on the rear diff. What came out was yellowish, with maybe tiny metal flakes in it. That is a 'maybe' - it could have been picking something glittery from the diff pan - or that could be wishful thinking...
So, it's over-filled with something, which doesn't look nice. I'm assuming some sort of water ingress, but I can't think where. The diff pinion seal looks to be intact. It's completely dry around about there. There's no sign of any leakage through the wheel bearings. Next thing to check will be the breather pipes. That's on today's job list. When I drain the old oil later, I will post a pic.
But, assuming I can find and fix any place where water might be getting in, what then. Do I just fill the diff with new oil? Do I need to pull it out and clean off? Should I fill it with oil, run it for a short while, then drain and refill. Is there any kind of flushing fluid I could use?
Longer term, I think the answer is definitely to pull it out and fix or replace. (Drooling over some Ashcroft options) But as this is my daily driver, I need something now to 'do the job' until I'm ready for a proper fix.
Any thoughts or suggestions?
Ta. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #760313 23rd Feb 2019 10:56am
I'd refill with the correct oil, run for a few miles (10, 20?) and then change the oil again. I'd also fit a magnetic drain plug, too. Darren
Post #760319 23rd Feb 2019 11:16am
landy andy
Don’t panic diffs, are very basic, and generally tough items. Possibly it was just overfilled?
Drain the oil into a clean container and see what you get. Then fill with new basic oil (it’s not expensive), then again drain after a few hundred miles, and check again.
Do you know how long oil has been in there?
Post #760323 23rd Feb 2019 11:24am
donmacn
Thanks guys.
I'm afraid I don't know how long the oil's been there. It won't be too long. Maybe a year and a half/5 to 10k miles. I will have the paperwork somewhere, but as usual I'd need to dig it out....
I'll see what happens with the drain plug - for all I know it could be magnetic anyway. If not, that's on the shopping list.
Like I say, I'll post pics of what comes out.
Off down to buy some oil now Donald
in the past..
Post #760325 23rd Feb 2019 11:36am
It may have drawn water in through the breather, quite a common problem.
Post #760339 23rd Feb 2019 12:33pm
donmacn
Interesting times, interesting times! I can tell this is going to be another 'school day'.
So here's what came out of both diffs -couldn't be more different! The black stuff is the front - and it's as black as it looks; the salad dressing is from the rear diff.
If I'm reading the WSManual properly, each diff should have 1.7L of oil in it.... I haven't measured this yet, because I'd get filthy dirty, but it looks like a lot more than 1.7L in both cases.
So my thoughts....
Rear axle is taking in water somehow. There is definitely nothing getting out, as far as I can see. Even overfilled with all this stuff in it, the seals are good. Guessing the casing would have to be cracked or punctured somehow. I think this is unlikely because it doesn't get that sort of use, and it was a brand new/take off about 5 years ago.
Front axle - does it look like it's just simply been over-filled, or have the swivels leaked into there? If they have, is that a 'swivels off'/replace seals job? Could I just add more grease in there; top up the axle and use it temporarily.
Rear axle breather. This is a relatively short hose - terminates up in the chassis X-member that supports the forward ends of the rear A frame.
It has this fitting on the axle end.
What is this? It reminds me of one of those 'Snap!/Oh- Censored !' fittings..... I was expecting to see a banjo bolt and washers. Because I don't know what to do with this, I haven't taken the breather pipe off to check if it's cracked/leaking.
The diff casing has these holes in it - but as far as I can see they are irrelevant - they don't seem to go all the way through..
So, having seen all that, what do you guys think?
Ta Donald
in the past..
Post #760348 23rd Feb 2019 1:44pm
donmacn
Ok, so some further digging about the web suggests this is what I have on the rear axle...
and that to remove the pipe from this, it I just need to push the red collar down into the brass fitting. I'll try that shortly.
On the one hand, it seems to me like quite a poor thing to have, instead of the threaded banjo nut, but I guess it's standard fitting on newer Defenders. Does it not cause problems at all? Are you supposed to remove/lever out the brass bit and check it's sealed into the axle casing?
On the other hand, if that's all it is, and I can't replace it with anything better, then I guess I just take it off, check that it's working and stick it back in again. At that point I'm completely stumped about where any water could be getting into the rear axle.
Assuming that's the issue. Does that oil in the pic above look like 'water ingress'? Donald
in the past..
Post #760357 23rd Feb 2019 2:45pm
LR90XS2011
Yes rear looks like water ingress, I would suspect the breather rather than anything else. a lot of front axles have black oil in them, it is just some of the swivel grease passing the seal, I wouldn't worry about that too much it wont hurt, start to worry when oil starts to come out of the swivel seals DEFENDER 90 TDCI XS,
Post #760358 23rd Feb 2019 3:03pm
MK
Those swivel-to-diff seals are really loose allowing grease to migrate to the diff. Puma 110" SW
Post #760363 23rd Feb 2019 3:29pm
donmacn
Well, that's the oil changed in both diffs. Can't take it for a run at the moment, but I bought enough oil to drain and refill again in the near future.
There was about 2.5L of oil in both diffs. I got the rear breather pipe out of the fitting OK, and it's not blocked - but I definitely wouldn't bet the mortgage on those fittings keeping water out. I see that Gwyn Lewis does replacements for these axles, which involve tapping a thread into the casing. I'll be dropping some £ on those very shortly.
Changing the diff oil was a job I'd never done personally before, always left it to the garage, but once done, I wonder why I didn't. Nothing to it.
However....
Have you got the 'second sight'?
While lying under the car and looking about, I noticed that on the NS, the outer swivel seals are actually leaking, and the seal retaining plate looks very, extremely fragile.
I'd noticed some early pitting on one of the swivels, and was planning to do a refresh of the hub assembly. Looks like that's going to get done sooner than I thought.
Thanks for all the advice and comments. Donald
in the past..
Post #760398 23rd Feb 2019 6:48pm
I had some water get in my rear axle when I had the pinion oil seal go, to the best of my knowledge the breather wasn't the issue on mine.
But I presume you have no pinion oil seal leaking?
Looks lime you've caught it just in time, and the rear on yours is very bad far worse than mine was and it does go like mayo.
As mentioned though, the Diffs are pretty tough and you should be okay.
Some of the water can migrate up around the half shafts too, but there is little way of flushing it except for as has been mentioned change diff oil. Leave a few hundred miles then drain abd replace again.
Reminds me, I might do the same on mine too as it was much the same scenario only much less water than you experienced.
Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #760399 23rd Feb 2019 6:49pm
donmacn
Hey Steve, no the pinion looks dry as a bone. And as I said, no sign of anything leaking at the hubs either. I'll sort the breather with Gwyn's kit and see where it goes from there. Donald
in the past..
Post #760401 23rd Feb 2019 6:59pm
Water ingress through the crappy breather into the rear axle cost me an ATB. Not happy!
A Gwyn Lewis breather upgrade is the way to go
Post #760459 23rd Feb 2019 9:49pm
