Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Interesting - good plan to use a top-quality GL4/GL5 oil. I always stayed as close to spec as follows: Click image to enlarge Keen to hear other views, but your idea currently sounds good Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
4th Feb 2019 10:50am |
andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82 |
Thanks to you Martin for kicking this thread off. Sure helped me and I think I saw over 150,000 views....
4th Feb 2019 10:07pm |
Interested to hear if a GL5 (Motul 300 Gear Oil) which is a 75W90 oil in the diffs will be ok. LR seem to suggest a 85W90.
Any thoughts? This is what the LR dealer put in last time. Click image to enlarge |
13th Feb 2019 12:13am |
75w 90 is absolutely fine. Darren
13th Feb 2019 10:29am |
Andy T Member Since: 25 Aug 2017 Location: Bucks Posts: 218 |
Have followed the advice on this thread to the letter and just want to thank those who have imparted their wisdom. Amazing..
14th Nov 2019 12:50am |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
Evening all, can I ask what the general consensus is between the two types, Mtl v Mt90.
I will be using the oil in the six speed Puma gearbox, online opinion would appear to vary with little difference in applications bar viscosity. Thanks in advance. |
15th Dec 2019 8:28pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
Just ordering oil and bits for my first ever oil change on my 2014 2.2 110 DPF. Found the info from Advanced factors website very helpful and concise as to the volume you put in.
Engine Oil without DPF 6.9 Litres (LR info above is 7lts, but assuming 0.1l is put in the filter) Engine Oil with DPF 6.9 Litres Front Diff Oil 1.7 Litres (LR info above is 1.6l) Rear Standard Diff Oil 1.7 Litres (90) OR 1.85 Litres (110) (LR info above is 1.6l) Transfer Box Oil 2.3 Litres (Not mentioned in LR info) Manual Gearbox Oil 2.2-2.4 Litres (refil and dry) Power Steering Fluid 1.6 Litres Coolant 8.2 Litres up to 50% Antifreeze mix (To suit climate) Going the motul 300 route for gears, transfer and diffs as that way i can't get confused. |
27th Apr 2020 2:38pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
Renewed my gearbox and transfer box yesterday, straight forward following this thread. Thank you
I used Motul 300 gear oil for both, the only tricky part was the transfer box fill plug. and don't forget a funnel for the gearbox drain so it doesn't hit the cross support and run everywhere. Not sure what oil was in the gearbox prior but there is a noticeable improvement with gear changes, its quite expensive oil but worth it i think. 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
17th May 2020 8:33am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 744 |
So for the gearbox/transfer case and diffs I can just use this “ Motul Gear 300” in 75W90
Car is a 2010 puma 110. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
15th Sep 2020 12:07pm |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 216 |
Can anyone confirm this stuff is OK for the diffs in a Puma?
75w90 Synthetic Gearbox Oil GL-4 GL-5 5 Litres 5L by Westway Lubricants Ltd https://www.amazon.co.uk/dp/B0185RDD3A/ref...BFbNBAQKZT It seems be reading through this thread but just wanted to double check. Thanks |
25th Sep 2020 11:32am |
Yes, that'll be fine for diffs and transfer box. Darren
25th Sep 2020 12:36pm |
So just went into local dealer (needed a sump bolt)
Asked about gearbox and transfer oils whilst I was there Transfer case 2 liters (less than told here) €78 Gearbox 3 liters (more than told here) €88 Still trying to locate a local autofactors that has the motul 300 stocked in the shelf Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
25th Sep 2020 12:41pm |
I wouldn't get too hung up on Motul if it's not easily available. Any decent 75/90 gear oil will be fine. Darren
25th Sep 2020 12:46pm |
Thanks LandRoverAnorak, advice much appreciated.
25th Sep 2020 2:15pm |
