Home > Puma (Tdci) > Puma half shafts |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
Good job. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
12th Jan 2019 7:33pm |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 494 |
Britpart items fitted to my sister’s 90 maybe 2 months ago. Might be worth considering some corrosion protection, she’s not worried about minor cosmetics though!
Click image to enlarge Although the winter has not been too bad yet, there’s been plenty of road salting around here since around October. Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
12th Jan 2019 8:50pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 648 |
Hmm - I painted mine in quite a few coats of satin black before fitting. No sign of corrosion.
12th Jan 2019 9:01pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 373 |
Good point ! I will do something to keep the Corrosion at bay. 2015 90 XS Santorini Black
12th Jan 2019 9:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6050 |
Do Britpart do an equivalent to the 110 shafts? (LR072977 & 072976)
Sorry, just found them on island4x4 (https://www.island-4x4.co.uk/halfshaft-rear-britpart-tob500030-lr072977-p-37449.html) HMmm double edit; these seem to be for a 90, not 110 triple edit.... island4x4 show the same part number for a 110 also (https://www.island-4x4.co.uk/halfshaft-rear-110130-britpart-tob500030-lr072977-p-37448.html).... I was under the impression 90's were different from 110/130 ones... |
13th Jan 2019 12:12am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 909 |
The shafts are the same on the rear. same PN for both since 2004 IIRC Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
13th Jan 2019 1:22am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
Could you use Buzzweld (same as the rear crossmember kit) to protect them, and spray them before fitting? Keith
13th Jan 2019 11:53am |
I think I am just going to smear them with coppaslip like the road wheel flange facing.
That’s should stop it getting bad. 2015 90 XS Santorini Black |
13th Jan 2019 12:50pm |
There's always something needing done......
Inspired to go and check mine having read through all of the discussion, now added to the list of things to be done when the weather is a bit warmer. Keith |
13th Jan 2019 1:28pm |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 |
That's just what I did this week. Found that both sides are worn, OS more than NS. Got britpart onepiece replacements as they where about £50, compared to £350 each for genuine! Looks like a case of whip out the old and slap in the new. |
13th Jan 2019 2:20pm |
The OS was more worn on mine too on the rear, seems to often be the case regardless of 1piece or two.
Since I replaced mine with Ashcroft all around. (Except CV's etc.) mine has been transformed. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
13th Jan 2019 2:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16960 |
The offside shaft on a Defender will almost always wear faster and be more likely to break than the nearside due to being shorter and hence less elastic. There will be the odd exception but in general this will be the case.
13th Jan 2019 11:57pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
Funny you should say that, because that's what happened to me a few weeks back. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
14th Jan 2019 12:11am |
I wonder if roundabouts maybe anything to do with it? After all there are a lot of them.
After all the NS would spin that bit faster and the OS that bit slower in a clockwise roundabout. Is there the same occurance on the front on a regular basis? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Jan 2019 12:16pm |
