Home > Puma (Tdci) > Puma half shafts |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 333 |
I also swapped mine for ashcroft on the weekend. I had already worn out the second (original) pair. Let's see if Ashcroft lasts longer. Now only minimal play in the drive. If not, it's not worth buying expensive quality. |
14th Jan 2019 1:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19654 |
Blackwolf - I agree, I treat mine with a lot of mechanical sympathy. Although the sympathy isn't always returned.
My 2.4 had the factory 2 piece set up, they lasted up until around 65k. They were getting pretty much on their last legs though. Although I didn't realise it much before I changed them due to it being a very very slow wear rate. An amount of slop between gear changes and vehicle movement with the handbrake engaged are tell tale signs. Also a drive engagement like clunk is also, especially at low speeds. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
14th Jan 2019 5:18pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 373 |
Does anyone know if it’s common practice to fit rear half shaft flanges and a load of silicone sealer on the inside?
I found just that when recently fitting the one piece shafts. It was the side where I had an oil leak and was repaired under warranty at a well known Sussex main dealer. . Is this really a dealer fix for such an issue?? 2015 90 XS Santorini Black |
17th Jan 2019 10:18pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 646 |
My indie uses sealant but would have thought a main dealer would use a new gasket?
I wouldn't worry about it. |
17th Jan 2019 11:26pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Apologies if this has already been covered in another topic, but are they much of a job to swap? I keep seeing Discovery one piece rear ones for sale on eBay for very little (ie £25) and it's becoming quite tempting.
17th Jan 2019 11:29pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Pretty simple job Joe. Be sure to torque the bolts up properly as snapping one in hub is a PITA. A friend told me, honest. 🤥
18th Jan 2019 7:23am |
Hi Scotm
Thanks. I was referring to sealant completely filled up on the inside of the flange and then fills the area where the shaft fits. Seems like a bodge to me. The gasket on the flange was fine. 2015 90 XS Santorini Black |
18th Jan 2019 10:19am |
Ah- that does seem like a bodge!
18th Jan 2019 7:24pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
trying to hide the fact the oil seal at the back of the wheel bearing is U/S perhaps DEFENDER 90 TDCI XS,
18th Jan 2019 7:49pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
Is it just me or do those studs looks a little too short / nuts not on far enough? |
19th Jan 2019 12:08pm |
This comes up regularly and whilst many don't like it, they come from the factory like that and so is clearly not a problem. Darren
19th Jan 2019 2:16pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 562 |
Which ex disco half shafts would I need for the rear of a 110 Puma. There are loads on eBay and I would end up with the wrong ones.
19th Jan 2019 4:04pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7711 |
That would leak down back of disc. Not sure on why they would fill a drive member with silicon. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
20th Jan 2019 9:45am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1287 |
As there is some play in my drive flanges I am thinking about doing the same. Are the ones needed for a 2012 110 Puma 10 spine, 24 spline, or something else? Any info much appreciated so I don't end up buying the wrong ones!!! |
20th Jan 2019 12:36pm |
