Home > Maintenance & Modifications > Difflock drain plug |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
which femco fits a 300tdi ?
3rd Jan 2019 9:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5641 |
Why can’t you order online??? Or am I missing something somewhere??? Andy |
3rd Jan 2019 9:02pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
Not 100% sure at the moment, but there's a few posts nearer the top of this thread which say that the folk there are pretty helpful.
Failing that, I'll get the difflock version. I think they are the same anyway. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Just to confirm that
http://www.drainplug.co.uk/index.html Is the place to buy these. Just off the phone to them and they could not be more helpful. The Td5 doesn’t use the standard M16X1.5 but a slightly different version. They are also over £10 cheaper than Difflock, who the supply with them. Andy |
4th Jan 2019 11:16am |
Looks identical to the Femco one. Do you know if there is any difference in manufacture or cost?
4th Jan 2019 4:10pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Thanks Chaps...something else I didn't know I needed...
So at around £50 compared to a standard Defender Drain Plug at £4.12 (Inc VAT) Which is to be be replaced at each Drain, so to break even this required 12 Service Intervals or 145K Miles at 12K Servicing or 73K Miles at 6K Servicing. The No Spill / Ease of Servicing argument wins out I guess...I feel an order is imminent SKIP https://www.defender2.net/forum/topic83242.html |
4th Jan 2019 4:48pm |
It cost £33.60
So in your maths in 8 Services it has paid for its self I service every 5thou miles so will soon pay for its self, it also then drops the oil straight into the old oil containers. Clean hands, no spilling and no oil tray to clean. Also far safer/nicer for the thread on the sump. |
4th Jan 2019 5:24pm |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Sorry not sure how the prices compared. We had credit to use on amazon.de so got it from there for €32 https://www.amazon.de/stahlbus®-Ölablassventil-M12x1-75x12mm-Stahl-Komplettset/dp/B01AMXATSC/ref=sr_1_8?ie=UTF8&qid=1546624633&sr=8-8&keywords=Stahlbus |
4th Jan 2019 5:59pm |
Our man maths was even easier to work our than that! Because of the hard work of Defender does at our off road school, we actually change our oil and filters every month. So it was really easy to justify for us for the ease of the change. |
4th Jan 2019 6:05pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 729 |
Would it make sense to have these on the gearbox, t-case, and the diffs too? I'm thinking the slim profile ones, even for the one on the sump.
IF it does make sense, will these plugs clear the holes in any diff guards or gearbox guards? |
5th Jan 2019 5:32am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1308 |
Given the frequency of oil change, I think it doesn't make sense for anything other than the engine oil.
Also, a number of those have plugs which are flush to the body. The Femco ones would stick out and could get easily damaged, especially in the diffs. |
10th Jan 2019 8:43am |
Also I like magnetic drain plugs in my diffs and boxes.
10th Jan 2019 12:55pm |
Thanks for the input!
So just the engine sump it is. For the record, they did mention something about magnetic versions or something equivalent. You'd have to contact them though. |
11th Jan 2019 1:37am |
BykerPete Member Since: 02 Feb 2015 Location: Midlands Posts: 159 |
I also have a 300Tdi (1997). Please could you tell me which thread size you ordered for the sump plug. Thank you. Pete. Drink Coffee, Talk to Strangers and Take Photos. |
26th Nov 2020 2:49pm |
