Home > Maintenance & Modifications > What jack do you have? |
That's very nice, but $1000 Is it twelve (approx.) times better than a high lift? Darren
30th Mar 2018 4:51pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Got a bottle jack from a merc van
30th Mar 2018 9:52pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Ditto - use it with a piece of cut down waffle board on soft ground. Also drift the pin out & remove the U shape on the ram & replace with a large washer to jack up the D4. |
30th Mar 2018 10:35pm |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 169 |
While it is expensive (ouch...) I think that ARB hydraulic jack looks the bees knees. Hi-lift works, yes, but it can be finicky. Doesn't like the slightest bit of dirt and operating it can be sketchy.
I'll be getting one of the ARB ones when they release it and get rid of my hi-lift. Should be far easier to operate. |
31st Mar 2018 6:18am |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 725 |
I dont have any proper jacking points
I.e. i have a normal bumper, sills and crossmember I do quite a bit of offroading and have a hi-lift Jack and also waffle boards I wus thinking of using the waffles for a base on soft stoney ground My Q is Where would the best place be to jack mine up front and back??..some where, where its not going to damage anything Mt Arran |
3rd Apr 2018 9:30pm |
You have got proper jacking points, front and rear. Underneath the front bumper are two inset tubes with rubber bungs in them, and in the rear crossmember are also two inset tubes. You can buy an adapter for your hi-lift that will enable you to use them. Darren
3rd Apr 2018 9:37pm |
You have to be a bit careful with the Merc jacks as they're quite a lot taller than the LR equivalent. If you get a flat tyre on the off-side, if can be a challenge to get the taller jack underneath the thicker axle casing, particularly if you need to use a spreader board of some description. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
3rd Apr 2018 9:45pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19621 |
All of the above that LRA suggested.
If you go to Thornton Breakers you can get a brand new Genuine take out jack for easy the same price as that merc one. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
3rd Apr 2018 10:14pm |
I used my new Hi Lift I had today for the first time, funny enough not for my 90 though.
It did an excellent job of lifting out some fence posts set into the ground. (Not concreted.) Bolted a piece of 75x75mm timber vertically to each one with some long m10 tested coach bolts 2x and the jack pulled them straight up and out with ease. Great bit of practice that is safe too, saved a lot of work! I'm glad I bought it as it can do multiple jobs. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Sep 2018 4:12pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
TMax 4ft jack for me
Click image to enlarge Half the price of the high lift and after 4 years of living on the roof rack it still works fine. Great bit of kit that I've used for everything from changing the wheel off road to lining up the front skid plate while trying to fit it I originally bought the 4ft because it fits behind the seats perfectly, but it takes up less room and looks far cooler outside Bottle jacks are fine for tyres, but are naff all use if you need to take the weight off the axle. 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
15th Sep 2018 7:54pm |
They have their uses. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
15th Sep 2018 8:09pm |
Gilloverland Member Since: 12 Nov 2017 Location: Yorkshire Posts: 61 |
Ex TD5 Disco bottle jack for me and a Hi-Lift.
16th Sep 2018 9:08am |
Ex TD5 Disco bottle jack now installed also t bar jack and a Hi-Lift but not for jacking landy but splitting logs and ex sprinter 3.5 bottle jack for service work
Click image to enlarge |
16th Sep 2018 9:17am |
