Home > Maintenance & Modifications > Puma front pads and discs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19611 |
The Sealey 3T each 6T a pair are pretty good. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
15th Aug 2018 11:18pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4944 |
a little Trick, if you have an old spare steel wheel, take that off and place the hub in there so that you can wind off the disc. basically you are using the wheel as a jig for the hub, makes tapping in the bearings easier too, as the wheel is flat
My dad loved it, as he used to have a little trouble with getting bearings back in, If you don't have a steel wheel, then id just buy on off ebay, just to use as a jig. I kept my old spare wheel for this purpose Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
16th Aug 2018 12:56am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
Another quick question, possibly not the last, does anybody know the part no for the bolts you need to replace. Or alternatively the dimensions and material.
Thanks Keith |
19th Aug 2018 8:55am |
https://www.landroverworkshop.com/diagrams...iscs_44959
Front Brake Caliper Bolts Qty 4 SYP500090 Front brake disc to hub Bolts Qty 10 UYG500030 and two RFD100000 if you sticking with as built |
19th Aug 2018 10:40am |
Having changed disc's on several Range Rovers, Disco and Land Rovers over the last 30 plus years the only advice I can give to add to what's been said already is :-
Make sure you get the correct part, some sellers don't know that there is a difference on some models, from a reputable company. Invest in a hide or soft face hammer to prevent damage to the new disc ,I have seen them shatter if a metal hammer is used. Make sure you get the new disc on square to the axel and don't rely on pulling it square with the bolts as a new one can jam and the bolts feel tight. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
20th Aug 2018 10:02am |
Do I need to torque the hub nuts when I put it all back together? Assuming I do but how do you do that with the box spanner?
Thanks Keith Keith |
6th Sep 2018 7:13pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 559 |
Does anybody have the wear limit measurements or tolerances for 110 Puma front discs. I do a fair few miles but may only touch the brakes ten times on a 25 mile commute. I don’t want to change them if they’ve got loads of life in them. Current ones have done about 40000 very gentle miles as have the pads with lots of life in them.
13th Jul 2019 10:42am |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 365 |
The Haynes manual says, Brake disk pad thickness 3mm. That's how it's written so i assume it means disks and pads.Your disks should be fine after only 40k if not abused. 130 crew cab
98 V8 Disco |
13th Jul 2019 11:53am |
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 |
Use one of these https://www.lrparts.net/hub-nut-socket-52m...-jobs.html /Hal |
13th Jul 2019 5:11pm |
Front disks thickness new 24 mm, minimum allowed 22 mm. Same numbers for rear disks are respectively 16.1 mm and 14.1 mm. Took the numbers from the certificate my dealer had to issue for the Swiss MOT this week. The measured thickness on my 110 after 101.000 km which is still on its original factory disks was 22.6 mm front and 15.2 mm rear, so still well within spec. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
13th Jul 2019 5:44pm |
Thanks
That’s exactly what I’m looking for |
13th Jul 2019 5:53pm |
