Home > Technical > 2.4 TDCI Power Issues |
Check that the battery earth connection is tight. Darren
30th Jul 2018 8:11am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
Volume Control Valve. Probably the first thing I would have changed.
30th Jul 2018 8:26am |
GreenArmour Member Since: 18 Nov 2017 Location: Chessington Posts: 8 |
Thanks LandRoverAnorak - tried that, including a change of battery |
30th Jul 2018 9:17am |
Thanks Blackwolf - I have seen your name pop up in loads of posts so appreciate your response on this one. Is the 'volume control valve' the same thing as the 'fuel injector pump vapour sensor (part number LR009837)'? Item 4 on this diagram... https://www.landroverworkshop.com/diagrams...mp_45001#4 |
30th Jul 2018 9:18am |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 228 |
Really long shot, mine did this intermittently for about a week before the water pump died
30th Jul 2018 10:07am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
^^^ Yours might have been going in and out of limp mode due to temp rising/water not circulating? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
30th Jul 2018 10:14am |
Ian you’re completely right I think that’s exactly what mine was doing, no warnings or temp gauge rising, just periods of no power. Warning lights etc only when it dumped all the coolant on the road!
30th Jul 2018 10:22am |
Yes, that's the thing. It may not of course be your problem, but it is usually the first thing to suspect in the case of poor running in the absence of DTCs, since the parts of the fuel system it affects are poorly monitored. If it is sticking and is not sufficiently responsive it is entirely possible that the fuel rail pressure is not reacting quickly enough to increased demand, such as the off-throttle/on-throttle sequence. The first time I had one fail I was convinced I have a fuel contamination issue leading to the filter blocking, since I would get fuel starvation symptoms (fine on tickover but massive misfires/stalling etc when accelerating). If you stopped for a couple of minutes (usually I would drain some fuel out of the filter), then start up and it would be fine for a while, then repeat the cycle. Eventually the "fine" intervals got shorter and shorter. There were no fault codes at all. Eventually (and after trying many fuel related things) I spoke to a main dealer's senior tech (a very helpful person who has provided me with advice on many occasions) who said that he would change the VCV and if that didn't sort it the EGR (which is disabled anyway on my Defender). New VCV and all was right as rain. His comment was that the VCV is absurdly fragile and is very prone to failing, especially if any water or dirt gets in the fuel. He also said that his dealership changed them very regularly and found that it was the single most common fault with the Ford-engined Defenders. The Ford dealer I bought my replacement from sold so many that the parts man knew the part number off the top of his head and kept a stock under the counter. In the end I came to the conclusion that my problem was indeed fuel contamination, since I had an unhealthy dose of the dreaded diesel bug, but it wasn't blocking the filter as I had thought but had instead knackered the VCV. Prior to changing the VCV I had dropped the tank and cleaned it, cleaned all the fuel lines, and had all my fuel professionally "polished" (it was shocking how much crud and detritus came out of supposedly clean fuel). |
30th Jul 2018 10:24am |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Your symptoms are the same as I had some time ago. The cause was the cylinder head temperature sensor was cutting power as the temperature rose above normal, there was no rise shown on the temperature gauge. I drove 150 ish motorway miles with no problem, but in traffic before and after the motorway I had power loss. No fault codes. I was convinced that it was bad diesel. Turned out to be a small leak in the radiator.
http://www.defender2.net/forum/topic54988.html The point is that the Cylinder Head Temperature Sensor reduces fuel rail pressure when it goes outside its normal range. It seems to be much more sensitive than the temperature gauge. When it operates there are no fault codes. It quickly returns to normal as the temperature drops. At motorway speeds air flow through the radiator is high enough to counteract low coolant level/low coolant flow. To reduce temperature in the cooling system it cuts the aircon. I was so convinced that the problem was fuel related that I did not check the coolant level. After returning home I drove to my independent and suggested that it was a fuel related problem. He took it for a test drive and a mile or so away from his garage it cut out and would not start. He checked levels as a matter of course, added water and all was OK. Anyway if the water level is OK it might be worth while to change the CHT sensor and check the cooling system. Be Lucky |
30th Jul 2018 1:07pm |
Thanks Minch - been doing this ever since I bought it, 8 months ago. I would think the water pump would have given up completely in that time |
30th Jul 2018 8:24pm |
I spent ages trying to prove it was all temp related by monitoring the digital readings on the ultragauge. My conclusion was that it wasn’t as once up to running temp you would expect that it would happen again (after a 2 min off reset) a lot quicker than from cold... I have been wrong about the turbo, actuator, maf, map, boost pipes, wiring loom, fuel filter so not ruling out being wrong about temp either |
30th Jul 2018 8:37pm |
VCV on order! Please, please, please let it be that |
30th Jul 2018 8:42pm |
Can the Hawkeye to the ECU learning for fitting the new VCV?
31st Jul 2018 9:26am |
Mc071963 Member Since: 06 Jan 2018 Location: Hertfordshire Posts: 48 |
all very interesting ...... I'm watching from a far !! TD5 90 in Hertfordshire
31st Jul 2018 1:00pm |
