Home > Puma TDCi > The strip down begins, TDCI head-gasket??
Page 6 of 7 <1234567>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #717220 11th Jul 2018 8:38pm
UtilityTruck
Seconding other comments; great thread and thanks for sharing.
Really there are surprisingly few of these type of threads on the forum considering the general reputation for LR owners to tinker. 2014 Keswick Utility 2.2
Post #717229 11th Jul 2018 10:14pm
MK
Thanks a lot.
When I was replacing the front crankshaft seal last week I was wondering about the issues you perfectly addressed.
Thumbs Up
ian series 1 wrote:
Hi MK
There is a trick to seating the seal,
Take the cover and apply the sealant,loosely fit the front cover with 2 bolts at the top,
Don’t tighten them, just let the cover “hang”
Then put the 2 10mm nuts on the bottom of the cover, again just pinch them up so the cover can still move.
Install the seal, then gently tighten the two top and bottom fixings,
Then put all the rest in and tighten up, the seal will find its centre, as they are quite hard seals,
Always done it this way, and never had any issues with leaking seals (except mine! But that was the crappy cover)
When the TDCI came out, you couldn’t get your hands on the special tools, not cheaply anyway, so there was always a workaround! Wink
The timing chain that I took out was an aftermarket one, I’ve no idea how long it’s been fitted for? but only the chain, tensioner guide, and tensioner had been fitted,
The cam sprockets, and pump sprocket were genuine Ford,
As were the other guides.
I brought it with 86,000 miles on the clock, so who or why it was fitted I don’t know?
It’s now on 140,000, apart from very slightly worn cam sprockets there wasn’t much to worry about.
The kits that I fit (at work, and here) include every guide and bolts, tensioner, 2x cam sprockets, 1x pump sprocket, crank/oil pump sprocket, and the chain.
They cost around £200 If your going to do it, replace everything for piece of mind.
Timing pin kits are readily avalible for very little money.
Thumbs Up
 Puma 110" SW
Post #717248 11th Jul 2018 11:58pm
CaptainDan
Australia 2013 Defender 130 Puma 2.2 HCPU Alaska White
Hi Ian,, please to here that you have the 90 running again, I am at the point where all things have been checked and the next step is to remove the head so this is where it is going to get expensive, again Big Cry I just hope to ... that something is found with the head gasket or head if not it could be a new engine. Just had a quote today back from LR a short motor $5.5k AUD or $12k AUD plus fitting. Big Cry Big Cry
My question is are all Duratec 2.2l equal, are the 2.2's in the Ford transit the exact same as in the Defenders. There is a company here in Oz selling 2.2 & 2.4 Duratec engines for $6k. Just clutching a straws now.
Thanks
Daniel
Post #717278 12th Jul 2018 11:48am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Give these guys a ring.
Quoted me $5.5K plus $1k to fit.
http://transitauto.com.au/
I stripped mine today found crack in #4 piston.
Funny thing was that it was bringing up #2 cylinder misfire.
Post #717279 12th Jul 2018 1:14pm
CaptainDan
Thanks Harold I will get in touch with them
Daniel
Post #717281 12th Jul 2018 1:22pm
ian series 1
Hi Daniel
That sounds like it’s an expensive repair Shocked
The basic blocks are the same, but it’s always worth a visual check to confirm it’s correct,
The sump will have to swapped, but not much else.
2.4 and 2.2 blocks are different, it’s not just bore size, you will find they have different bolt holes cast in the front,
And possibly more?
Earlier 2.4 duratorqs look similar, but are totally different.
I’m supprised at the prices you were given, Short engines are cheap here now, you can pick them up reconditioned for as little as £1000, a few years ago you couldn’t buy one for under £2000.
I’m not sure what the exchange rate is, so not sure what that works out to in £s?
I hope you have a positive outcome with yours, I would get the head tested and skimmed personally,
You may have read, the guy that did mine said the Ford blocks were practically bomb proof, and I have no reason to doubt him.
Ian 80" 80" 86" 88" 90"
Post #717282 12th Jul 2018 1:29pm
ian series 1
Did you have much water in the oil? 80" 80" 86" 88" 90"
Post #717284 12th Jul 2018 1:34pm
Big Harold
Unnecessary quote removed
I found with my engine that if you rotate it the timing mark on the chain will advance 1 tooth per 4 revolutions of the crank.
Post #717285 12th Jul 2018 1:36pm
Big Harold
None just misfire and blow by into the crankcase.
106000km
Post #717286 12th Jul 2018 1:39pm
Big Harold
Daniel
What are the simptoms of your engine.
Mine will loose coolant out of the header tank/ bottle from the cap centing.
I have just purchased an Iveco cap that has an external drain hose.
I haven't fitted yet but will let you know the results was recommended by someone on AULRO
Mark
Post #717288 12th Jul 2018 1:42pm
ian series 1
I couldn’t get my old chain to line up correctly?
I rotated it so many times I nearly passed out Rolling Eyes
Like you say, 4 turns on the new one, and it’s back to where it should be. 80" 80" 86" 88" 90"
Post #717290 12th Jul 2018 1:46pm
Big Harold
Hi Ian,
Do you know what the availability of rebuild kits is like over there?
Can you recommend any supply centres?
Mark
Post #717419 12th Jul 2018 10:52pm
ian series 1
Hi Mark
Try theses guys.....
http://www.lymmengineparts.co.uk/
If you search under Transit, rather than Defender, you will find the rebuild kits.
Will post worldwide.
Post #717436 13th Jul 2018 6:15am
CaptainDan
Hi Harold
Some background to my problems are described at
http://www.defender2.net/forum/topic62320.html
I have not heard back from the guys in Clayton as yet. What would be the purpose of the Iveco cap and drain? wouldn't you still loos the same amount of coolant? What is really frustrating with mine is that it runs fine with no power loss just coolant loss. If it ran like a hairy goat I could understand it be it simply runs fine.
Daniel
Post #717441 13th Jul 2018 7:25am
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
