Home > In Car Electronics > Fridge power connector
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Hi all,
I run a waeco cf fridge in the back of the defender which receives power through its standard cigarette socket. This can sometimes gets dislodged and puts the fridge into error mode. Are there other types of power connectors available that I could replace this with?
Ta
James 2002 110 td5
Post #716355 5th Jul 2018 10:22pm
Replace both the plug and socket with male and female Hella or DIN connectors. They have a much more definite connection. Darren
Post #716358 5th Jul 2018 10:34pm
zsd-puma
Hella connectors;
https://www.ebay.co.uk/itm/HELLA-POWER-DIN...rmvSB=true
You could use a small Anderson connector (total overkill)
https://www.ebay.co.uk/itm/PAIR-X2-ANDERSO...rmvSB=true
SAE Connectors;
https://www.ebay.co.uk/itm/SAE-Plug-Connec...1910550824
There are also more specialist connectors, which have greater water resistance, but they're less standard so, you would have to have adaptors made up to connect anything else.
Post #716359 5th Jul 2018 10:40pm
VeeTee
Netherlands
I had exactly the same problem. I replaced the plug and socket for a decent sized anderson connector. No problems since. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #716361 5th Jul 2018 10:51pm
zsd-puma
If you ran large battery cables through to the back, an Anderson connector does give you an extra location for jump starts etc.
Post #716372 5th Jul 2018 11:37pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
I used a 'Magcode connector':
I think it's a german system, I purchased it at Landreiziger: https://shop.landreiziger.nl/componenten/connectoren/magcode.html
Main reasons to choose for Magcode is that they make a 90 degree angle and sit relatively flush. The pro version is lockable and can handle 25A continuously.
They're also quite shallow, giving more possibilities in locations to choose from. You see it from the back installed in the top of the rear corner cover here:
They take no effort to connect.
Not cheap though but worth it, I think it was 40 euro for a male/female pro set.
Greetings,
Joris
Post #716387 6th Jul 2018 7:00am
jackl
England 2012 Defender 110 Puma 2.2 XS CSW Zambezi Silver
Just been having the same problem so have ordered these to try As they look good.
https://rover.ebay.com/rover/0/0/0?mpre=ht...2505156126
I like the way you lock the connection.
Post #716469 6th Jul 2018 7:10pm
Jimb1978
Thanks for the responses everybody. I’ll research the links and recommendations and I’m sure I’ll have some more questions. 2002 110 td5
Post #716477 6th Jul 2018 7:58pm
DSC-off
The Waeco 12v power lead is compatible with Hella sockets. That might fix the problem without cutting the plug off the lead, but you'll still need a Hella socket.
Remove the red part of the plug by turning it anti-clockwise then pull it off.
Post #716488 6th Jul 2018 8:50pm
Jimb1978
My hella socket arrived today so I'm going to give that a go. It was only £9 so the cheapest and easiest option to try first.
Thanks all Thumbs Up 2002 110 td5
Post #716791 8th Jul 2018 10:07pm
