Home > Puma (Tdci) > The strip down begins, TDCI head-gasket?? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6038 |
Very interesting thread.
Quite a cramped complex engine in comparison to a Td5 |
30th Jun 2018 3:47pm |
CaptainDan Member Since: 14 Apr 2017 Location: Victoria Posts: 53 |
Hi Ian
I am following your story with interest as I have the very same problem with my 130 and at the crossroads as to what to do. Having spent $8.8k AUD on the repair after the EGR cooler failed and having replaced in the last week the split radiator water pump and thermostat I am at a loss as to what to do next. I have a few options, everyone who has looked at the problem have told me its another cracked head or head gasket, the repair is only 20k old. If I take it back to the original repairer who are denying the head/gasket problem and they take the head off as you are doing and find that it is nothing to do with their original repair work then I will be in the position of having to pay again for their work and still have a stripped engine I have no confidence them anymore. I am thinking of a new engine and just keeping the original for parts and putting in a brand new one What are you thinking with the No.4 cylinder? Thanks Daniel |
1st Jul 2018 5:24am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Hi Daniel
It sounds like your having some bad luck with your Defender! The most annoying thing is still not being able to pin point something for real? Like I say, the combustion pattern on number 4 does not match the other 3 cylinders that well, So I’m hoping the gasket failed around number 4 cyl, and my eyes can not see it!? If the head comes back ok, I have no option other than refit it and keep my fingers crossed, I will flush the block, rad, and martrix, and like you replace the thermostat and pump, just so I know it’s been done. I am taking no chances with this, simply due to the amount of work involved stripping and refitting everything, It’s not a great engine to work around in situ. If I still have problems, then I would say it’s the block, in which case I would be looking at a short recon motor, I do have a 160,000 mile spare engine, but I think the way to go would be reconditioned, then at least there is guarantee on the block. I’m just glad I can sort this myself, I certainly wouldn’t want a garage bill for this repair in the U.K.! My cost is around £350 at the moment, most of that being the cam chain kit. I will certainly keep this thread going until I’ve found the cause, good luck with yours, and I hope you get it sorted soon? Cheers Ian 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
1st Jul 2018 6:44am |
Good news!
The head was ok with the pressure test, and no warping. I have still insisted on a very light skim, and re cut the valve seats, just to be sure that I’ve done all I can! Head kit came today, along with head bolts, rocker carrier bolts, water pump/thermostat, crank sensor, and all the gaskets. I’m picking it up Thursday night, so all being well I hope to be up and running on Saturday. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
3rd Jul 2018 6:37pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Great work Ian
I will be waiting with anticipation on the weekend to see how this goes. Makes my issues seem minor Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
3rd Jul 2018 9:59pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Reading the thread with interest. Wishing you the best outcome. Cheers Don.
4th Jul 2018 10:13am |
Cheers chaps,
Fingers crossed I covered all bases on this one, Hopefully I can report back on Saturday as being a success? The annoying part is, I’ve found nothing really wrong with anything 9 times out of 10 you can see the problem with H/G failure. I would have preferred to have found something that stands out, but sadly in this case nothing! The mating surface of the head had 2 tiny marks on it, (and they were tiny!) which is why I’ve decided to get it skimmed. Anything after this would indicate the block to be the issue.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jul 2018 10:38am |
Hi Ian
Ok so the head is good but what are you going to do about cylinder 4? is that why you have has the valve seats ground? my 130 is still running ok just still loosing coolant from the overflow bottle cap. Should be doing the chem test this weekend. Just got it back today after having the clutch repaired one of the double springs in the clutch plate had come adrift and was thrashing about inside. What else can go wrong? I have to sort out this cooling issue though. Daniel |
4th Jul 2018 10:46am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
Hi Ian,
That looks a bit scary all in bits so hats off you know what you're doing and saving labour rates I'm happy with doing basic things like oil changes on my series. Hope you get it sorted. |
4th Jul 2018 11:43am |
Daniel
Number 4 was the cylinder with an odd combustion pattern, if any water was entering the bores, I’m 99% this was the one? The bore looks good, as does the top face of the block, Obviously it’s only a visual check though. I can only hope now, that what I’ve done will be enough to cure the problem? Scott, It’s just nuts, bolts and chains assembled in an specific order... I’ve already been looking at its replacement... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jul 2018 1:03pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
Well, in defense of the Puma, I've heard of a lot more head and head gasket issues with the TD5 than with the Puma... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
4th Jul 2018 1:18pm |
Your right, h/g failure is almost un heard of on the TDCI,
My local Indy has only ever done one. I’ve never had any issues on the Transits I repair either. I did my TD5 Disco just before I sold it, which was typical! the plastic dowels had broke causing the head to move, Same as what happend with the K series engine in the Freelander's Both victims of Another wonderful LR cost cutting exercise! You can hear them now..... Head gasket dowels, Mmmm plastic or steel? Plastic or steel? Sod it, Plastic it’ll be fine. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jul 2018 1:28pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19606 |
Hats off to you Ian, that is some real in depth precision engineering work there involved.
Just a suggestion and you may do so anyway, but when you do fit everything and fire it up perhaps you could try some Millers diesel additive too? That should help clean things through especially the carbon deposits over time. I run it all the time and it's pretty good. It's been known before for some of the sprockets to have a tooth worn or even missing too. But most instances are pretty rare. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 Last edited by custom90 on 4th Jul 2018 3:03pm. Edited 1 time in total |
4th Jul 2018 2:10pm |
Steve,
Believe it or not I do use it, but looking at the injector tips, and piston crowns, I don’t think I will bother anymore! I even gave it a double dose the night before, as I was doing a nice long run. The internals are no cleaner than any plant equipment I’ve stripped that just runs on red diesel every day. I’ve seen a few bad chains and sprockets, I did a 2.2 Transit a few weeks ago, Only done 116,0000 miles Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
4th Jul 2018 2:25pm |
