Home > Puma (Tdci) > Should I clean engine ??
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Just returned from northern Mozambique. Had to a lot of driving through mud an rivers etc. The engine compartment has a lot mud everywhere. Must I clean the engine? Should I leave the sand and mud in case I damage the electrics etc?
Thanks
Anthony
Post #6233 12th Jan 2009 7:12pm
diffbeer
Clean it . Spray electrical areas with WD40 and leave to dry .Nothing like mud etc left there to initiate corrosion and acting as a grinding paste to all moving parts.
Post #7001 7th Feb 2009 2:38pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Same as above WD40 jetwash get rid,
Iv had no problems Thumbs Up
leve it running NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #7003 7th Feb 2009 3:00pm
jst
i would steam clean it yes. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #7010 8th Feb 2009 1:17pm
Laurie
Do it with a warmed up engine so it dries out rapidly.
Post #7011 8th Feb 2009 1:23pm
jst
and go for a drive straight after. (good practice after cleaning any vehicle)
i have always steam cleaned or pressure washed engines either off or running tdi, tgv, td5 - tdci hasn't been used properly yet so is yet to be done. Cheers
James
110 XS Utility
90 Puma Hardtop
Post #7013 8th Feb 2009 1:48pm
Bundubasher
Thank you everyone for the advice. I was a bit worried about those electrical connecting plugs around the engine. I will buy some WD40 and spry it on the electrical connecting plugs etc. And then spray the engine with carefully with water.
Regards
Anthony
Post #7041 9th Feb 2009 9:59am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
WD40 - never leave home without it Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #7050 9th Feb 2009 1:44pm
Laurie
On special at Lidl next Monday Very Happy
Post #7052 9th Feb 2009 2:40pm
fekete
Also excellent for removing oil off things and
driveways Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #7053 9th Feb 2009 3:06pm
diffbeer
If you dont have WD40 in SAFFA , use Q20 ,spray all connectors , pressure wash , and drive it dry
Post #7127 10th Feb 2009 11:21pm
