Home > Td5 > Steady Drop in MPG - WHY!?
Page 1 of 3 123>
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
A question for the TD5 Experts of Defender 2?! Very Happy
Truck: 90 TD5 15P
Over the past 5 months I have noticed a continuous drop in our MPG?
The first year of owning the 90 she was pretty consistent at 28MPG - even with various driving styles - Long journeys / Short town trips - mid length up to the highlands... 28 .. there or there about.
Since Oct 17 its steadily declined up to the point of after filling up coming down to the Lake District we are at 20MPG.
She had a oil/ air / fuel filter service in Nov 16. A full Transfer box / Gearbox / Diffs / Engine / All Filters change in Dec 17.
I've looked along the fuel lines, that i can get to and cant find any wet / leaky areas. All oil levels are correct...
Any suggestions? Question
 Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #694617 19th Mar 2018 1:12pm
Jack up vehicle and check for any binding/ drag at wheels, props & transfer brake.
Go for a run, apply no brakes when stopping & jump out and check for any unusual heat for same places.
If you can rule out the simple things then its on to other less obvious ones.
Post #694634 19th Mar 2018 2:52pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
are you simply driving it harder? or is it the cold? are your tyre pressures correct?
As above check brakes etc for binding.
Mine dropped off too, it was a slight boost leak and I was driving harder to drive the same speed. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #694637 19th Mar 2018 2:59pm
bogwert
I did change the rear pads a while back but I would have expected them to bed in by now.
I wouldn't say I'm driving harder, and yes I currently is pretty cold, although pretty standard for Scotland.. and its not been ice cold since October... I hope!
Tyre pressures, I'm pretty good at keeping them level and correct - but again a good shout, new MT's on there 3 weeks back so I'll endeavor to keep them correct.
a boost leak? Would this come from the input / output on the turbo? Now you mention that there is a slight dint in on the in hose by the radiator!? might have started to tear through?! Confused Chris
Post #694647 19th Mar 2018 3:19pm
zsd-puma
Weather getting colder. That graph pretty much follows the temperature drop through winter, including the latest cold snap.
Diesels take longer to warm up than petrol engines, and don't reach full efficiency until warm.
You'll also be running things like the heater fan, as well as heated screens and seats if fitted. You'll be using your lights more too. All that drains the battery which the alternator has to top back up which puts more load on the engine.
Try putting a bit of card board in front of the radiator and see if your fuel economy improves.
Post #694653 19th Mar 2018 3:32pm
grafty99
Would be worth having it plugged in and having a look at the injector trim. They may be getting worn and the ecu has reached its trim limit 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #694656 19th Mar 2018 3:43pm
bogwert
Hummmm... Ok, so see if it improves over the next few months... if spring does come! Laughing
If not, start plugging things in!! Smile Chris
Post #694661 19th Mar 2018 4:07pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Defrosting, demisting, fan on longer/higher, oil in engine thicker, oil in gearbox/diffs thicker, lights on more often, plus diesel reduces 1-2% in a colder climate, hence uses more fuel Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #694778 19th Mar 2018 10:42pm
Hufflepuff
You shouldn't be getting 20 mpg on a motorway run though in a 90, unless you were giving it full beans all the way down? The worst I ever achieved was 24mpg in a fully loaded 90 coming up through France at a steady 130kph. Normally in the UK I'm at around 28mpg the motorway at a steady 65-70mph. 2005 Td5 90 XS
1989 V8 110 CSW
Post #694800 20th Mar 2018 12:06am
geobloke
Hi Grafty. What is the trim limit?
Post #694825 20th Mar 2018 7:54am
bogwert
Had a wee look at what was the 'dint' in the pipe! its now a small tear! Shocked
Please excuse the mud, its from this weekend's green laneing, Friday afternoon is bath day!
Anyone know the part number for a replacement pipe?
I'm thinking it might be a mixture of the 2 cold weather and leaky pipe meaning the engine is working harder? Chris
Post #694851 20th Mar 2018 9:31am
It's good you may have got to the failure, it is what looks like a the bolt head just below that's caused the damage?
Proves monitoring the fuel economy religiously can be used as part of a maintenance programme.
Post #694878 20th Mar 2018 10:49am
bogwert
I think its defiantly a contributor!!
Now the simple 10 minute job to change the pipe.... AH!
Any shouts on the part number? cant find it on LRCAT! Chris
Post #694891 20th Mar 2018 11:23am
rallysteve
Looks like PNH102090 to me (cooling and heating > cooling > intercooler)
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #694905 20th Mar 2018 12:16pm
bogwert
Ah! Found a label hiding further down! PNH 102071! Thumbs Up
Guess I might as well just replace the whole length! Neutral Chris
Post #694906 20th Mar 2018 12:28pm
Page 1 of 3 123>
