Home > My Defender > Grafty's Td5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Great news on the new MOT 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
8th Mar 2018 11:19pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Yes, always a nervous time. Not so much the MOT itself but leaving my defender in the hands of someone else. All came back ok though which is good
Earl Grey tea and Fortnum & Mason buiscuits for the upcoming deal - what do you reckon Clayton? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
8th Mar 2018 11:23pm |
The next deal needs a bit of tweaking but there is a working (sort of) prototype 2002 90 Td5 Station Wagon
8th Mar 2018 11:47pm |
Moving along nicely then 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
8th Mar 2018 11:54pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4942 |
what about the rest of the forum? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
9th Mar 2018 6:49am |
Anyone from the forum who comes over can have tea and biscuits. It's a long way for a cuppa though procta 2002 90 Td5 Station Wagon
9th Mar 2018 8:32am |
you can post it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Mar 2018 5:06pm |
Ok lads hire a large mini bus! Tea and biscuits at georges! You would die if everyone turned up mind Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
9th Mar 2018 5:07pm |
We have commercial catering facilities at the campsite so I'm sure I could cope 2002 90 Td5 Station Wagon
9th Mar 2018 6:43pm |
Mc071963 Member Since: 06 Jan 2018 Location: Hertfordshire Posts: 48 |
Hi grafty99
wonder if you can help. I really like your mod's with the indicator stalks and the light stalk. I have a pair of stalks but am struggling to figure out the actually function of the switches. Do you happen to have any info on the pinout of the two stalks ? Cheers Martin TD5 90 in Hertfordshire |
11th Mar 2018 10:49pm |
Hi Martin.
I'm not sure about the stalk pinout as I had the two vehicles side by side. All I know is that the wire colours were the same. The LH stalk is identical in function to the defender item. The RH is the same except the slider adjusts the resistance through the intermittent wire and pulling the stalk towards you puts the wipers on constant for as long as you hold it. Hope that helps? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
11th Mar 2018 11:09pm |
How did you get them to work with self cancel? I have toyed with the idea of doing this to mine at some point, but then again I don't know much difference there is with the 300 and TD5 electrics wise. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
11th Mar 2018 11:32pm |
The self cancel works off the steering wheel the same as before. You have to change the cancel pins slightly but other than that it's pretty easy 2002 90 Td5 Station Wagon
15th Mar 2018 10:56pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
I'm all caught up with your thread again... looking beautiful.. the landy... Nice to see a good covering of snow foam.. I use it when the cars are very dirty... What happened with the Alcantara with the heat? 1993 200Tdi Defender 90
16th Mar 2018 12:59am |
