Home > In Car Electronics > Defender Security - Immobilise via inertia switch |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
yes, there is a thread on it, let me find it for you My 90 Project : http://www.defender2.net/forum/topic52774.html
2nd Mar 2018 9:54am |
2nd Mar 2018 9:56am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 706 |
Thanks Meeerrrk, I didn't have much luck with a search, then realised after posting that I'd spelt inertia wrong 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
2nd Mar 2018 10:36am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2040 |
I've sent you a PM Harry
2nd Mar 2018 8:45pm |
Thank you very much Screbble 2005 Td5 110 Hardtop
5th Mar 2018 7:34pm |
You're welcome Harry
5th Mar 2018 7:48pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
just ordered one of these -
https://www.landroverdefendersecurity.com/...f-2-2-tdci |
6th Mar 2018 11:39am |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
They got the idea of someone of here.. think it would cost around10--15 quid to source the components yourself as a one off so I font mind the profit margin...what I do think they could improve it. By increasing the length of the y connector to make it easier to hide.....as if spotted its a case of swapsy and there off... It will stop the dumb theif
6th Mar 2018 5:36pm |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 |
"...what I do think they could improve it. By increasing the length of the y connector to make it easier to hide.....as if spotted its a case of swapsy and there off... It will stop the dumb thief"
Although, getting the plug off [and back on] the inertia switch was/is a bu**er of a job and, on mine, required unscrewing the switch itself. Only a thief with tiny, strong, triple joined hands could manage to swap back, I feel... but then again, they can be clever bu**ers |
6th Mar 2018 6:16pm |
I dont know if the switch is open or closed when not engaged so someone who knows may comment on what happens if you simply pull out the wires from the inertia switch and join the ends thus making a circuit?Its always best to hide your security devices the best you can..prererably in plain sight!
7th Mar 2018 3:11am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 993 |
Has anyone using this method noticed it may take longer before the engine can be started? Someone over here said so and he was annoyed by it.
17th Mar 2018 10:35pm |
ssg Member Since: 01 Mar 2018 Location: North East Posts: 65 |
I have just fitted one of these switches, easy job, getting the switch end of the wiring into the passenger compartment was a bit of a pain. The switch doesn't affect starting unless it's off which does take a while to restart once reactivated. I am going to relocate the valve in the engine bay as an extra precaution.
21st Mar 2018 8:08pm |
Thank you! How long approx. is "a while"?
21st Mar 2018 9:59pm |
Unused some red solid copper coded wire taped to the actual wiring loom and pushed it downward through the bulk head grommet until I could see it through the fuse box appeture, then pulled the cable through. Complete job took about 30 mins in total, just an bit Ridley making the y connection and then finding the red wire to pull through.
21st Mar 2018 10:10pm |
