Home > Maintenance & Modifications > Mains input |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
What are you using it for as the current requirements will dictate what soze socket you need? 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
1st Mar 2018 5:23pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
I like these, which are small and available in 16/20/32A versions. They have a range of sealing options in the accessories section:
http://www.neutrik.com/en/audio/powercon/ |
1st Mar 2018 5:35pm |
Also worth noting that the vehicle body must be earthed (thus 3pin plugs required) also your legally on dodgy ground plugging a vehicle into 230V if your household electrical installation does not have an earthing rod or earthed shealthing on the incoming cable. 02' 110 TD5 Double Cab Rebuild Thread
1st Mar 2018 6:06pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
I’m looking for no more than 10A on a 3 pole supply, it’s just to supply my fridge and battery charger. I don’t like feeding a cable through the window so decided to go this way, I’m aware of the earthing requirements and intend to earth to the chassis and have a weatherproof ELCB in the supply line. Thanks for the link Intercept, I’ll check them out.
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
1st Mar 2018 7:12pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
I recently got this connection;
https://shop.landreiziger.nl/230-volt-voertuig-aansluiting.html It has been mentioned on a few other threads on here. |
1st Mar 2018 8:12pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 488 |
Bulgin Buccaneer - http://www.defender2.net/forum/post449301.html#449301 Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
1st Mar 2018 8:49pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 996 |
I can absolutely recommend the DEFA plug:
http://www.leab.eu/en/products/plugs-and-s...iplug.html Got the cable set A460785 (2,5 green + 1,5m black) and the 230V socket A460829 for £70 off ebay. The external plug went into the rear crossmember on the right hand side. The black cable routed over to the left and up inside behind the loud speaker, where I fitted the interiour socket. Click image to enlarge Click image to enlarge Click image to enlarge |
1st Mar 2018 8:51pm |
Thanks for all your suggestions guys, I like the look of the Bulgin and Neutrik connectors, will have to work out all the bits I need, sealing etc.
2nd Mar 2018 10:35am |
