Home > Technical > Td5 cuts out |
Oil in loom/red plug from injector harness, bad earth from ECM in the seat box, injector seals/washers but they will cause poor starting issues as well. Could even be crank sensor.
You could try a diagnostic plug in which may point you in the right direction. |
21st Jan 2018 9:45am |
Check your oil level Incase the injectors are dumping fuel in the oil Ray
21st Jan 2018 11:09am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2075 |
My old 90 did this. Changed the crank sensor with a genuine unit, problem solved.
21st Jan 2018 11:50am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4407 |
This sounds awfully like your ECU is on the way out. I entirely expect that if/when you check for fault codes it will flash up topside switch faults. This is usually one of the two capacitors within the ECU that fails to charge up causing the engine to just stop. With my 2003 it happened more often that not when decelerating towards a junction. Managed to keep the ECU going for over a year because the fault was so unpredictable, go months without any problem then four or five engine cutouts in a day. Replaced the crank sensor, check oil in the loom, replaced injector seals and top loom to no effect. Replacement ECU solved the problem. |
21st Jan 2018 12:47pm |
divethedeep Member Since: 17 Sep 2014 Location: sussex Posts: 32 |
Thanks for the promp reply’s.
I will check the suggested and update when I have a result Mark |
21st Jan 2018 12:52pm |
Should have said a Nanocom or Hawkeye will diagnose the topside error in minutes. Someone on here must have one close to you.
21st Jan 2018 12:54pm |
