Home > Puma (Tdci) > 2.2 fuel priming kit |
this may answer your question see below
http://www.defender2.net/forum/topic516-75.html |
12th Jan 2018 9:58am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 907 |
If you market it for the 2.4 then you might get more interest as the intank pump on the 2.2 might steal your thunder a little when it comes to priming the system.
12th Jan 2018 10:14am |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 226 |
When I had troubles with the fueling problem I was looking for a priming tool too.
Most written here is for the 2.4. The 2.2 is complete different! The 2.2 has an electric in tank fuel pump. No need for a priming tool! |
12th Jan 2018 11:12am |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Does the 2.2 work the same as the Td5 ie keep pressing the throttle?
12th Jan 2018 4:46pm |
have read work shop manual link below re 310-00 under fuel system air bleed low presser side and fuel priming kit
https://1drv.ms/b/s!AtZSoWFHDgnGhDi2WurSGNueOAvo |
12th Jan 2018 6:00pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
on a 2.2 you do not need a priming kit
it has a electric lift pump I have recently replaced the fuel tank with a 130L steel tank. and all I do is ignition on and off a couple of time to let the pump prime the fuel system I remember I have done it 10 times to start the engine same goes for changing fuel filter/ |
14th Jan 2018 2:25am |
The TD5 had an electric lift pump, the 2.4 didn’t. Ford/Landrover realised the mistake and gave the 2.2s an electric lift pump too.
14th Jan 2018 4:19am |
Thanks for all the replies.
So all is good and I just turn the ignition key .... job done. I am new to post 2001 Defender models and assumed the Puma 2.4 and 2.2 engines would have the same characteristics. Couple this with posts that just refer to Puma engines ie posted before the 2.2 then I can see I must be more discerning. Although I must say some of the parts suppliers also lump the 2.4 and2.2 together ie 12s caravan plug wiring loom. Anyway thanks for all the help on this and other questions and best wishes for a happy new year. Dave |
14th Jan 2018 8:17am |
While the 2.4 and 2.2 are the same basic engine, or rather same engine family. They have a huge amount of differences, with lots of bits that aren’t interchangeable.
It’s like saying a Morris 1000 has the same engine as a Mini Cooper S. They’re both BMC A-Series engines, but virtually nothing is interchangeable. |
15th Jan 2018 4:45am |
Reading 2.4 post and think it is the same as a 2.2 has cost me a lot of money. I even suggest to make an apart topic for 2.4 and 2.2 engines.
17th Jan 2018 2:52pm |
TopQ1967. I think that part of the problem may be is that a lot of posts that are referenced by recent posts were posted when the only Puma was the 2.4
Now I am aware there is a problem I will make sure that I look at the date of the original post. Although I have noticed some forum users even on recent posts dont advise what model they are refering to. |
17th Jan 2018 8:17pm |
I think you have a point Foggydave. So many people assume they're identical they don't think to mention what CC they have.
Then again lots of people seem to think the 2.2 in the Freelander is the same as the 2.2 in the Defender. They're actually totally unrelated engines, one's Peugeot derived and one is Ford derived. |
18th Jan 2018 12:30am |
