Home > Maintenance & Modifications > License plate location legality
Page 2 of 3 <123>
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Scania trucks used to come with a sturdy bracket for under bumper fitting. I bet the Scania parts still have them.
Post #665042 17th Nov 2017 11:37am
zsd-puma
LandRoverAnorak wrote:
zsd-puma wrote:
But providing the actual plate is an approved one you can put it where every you like on the front of the car so long as it's more or less vertical and visible from the front of the car.
http://www.legislation.gov.uk/uksi/2001/56...561_en.pdf
There is a bit more detail in the legislation than that. They say that the plate must be visible from the 'relevant area', which is a diamond shape at ground level with one corner under the centre of the plate and the diagonal leading away from it in line with the vehicle. The length of the diagonal, and hence the size of the relevant area, is determined by the size of lettering on the plate but for most regular vehicles will be 22m.
The implication is that the plate should be visible when standing anywhere within that diamond shape. However, what it doesn't do is define any viewing height, which still leaves a grey area. On the Bowler, for instance, if you stand within a couple of meters of the front then that plate below the bumper wouldn't be visible but might be if you knelt down.
Unfortunately, there are lots of instances like this in the various rules that govern cars, where there are some specifics defined but not enough to provide a complete answer.
I would stick with my original statement, so long as it's reasonably vertical and visible from the front of the car i can't see any traffic police drawing diamonds on the floor to check. The reason there is no height is because it would depend on the viewers height. I mean if you put it on the bulkhead then laid on the floor in front of the bumper you're not going to see it. But common sense dictates humans have the ability to stand up and look down. Screwing it flat to the top of the bonnet is basically a no no.
Post #665043 17th Nov 2017 11:39am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
ARC99 wrote:
Kit. This para is the one that you need to be aware of,
(3) This paragraph requires the plate to be fixed— (a) vertically or, where that is not reasonably practicable, in a position as close to the vertical as is reasonably practicable.
It is not a case of you prefer to put it but what is legally required.
Maybe I should give Bowler a call and ask them if that's their approved location for the license plate, i've got to ask them a couple of things about the Bulldog anyway. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #665046 17th Nov 2017 11:45am
Aluminium strip bar from Wickes is very useful for making brackets up.
Easy to bend, work and drill.
And you can either bolt or use adhesive, or as I prefer, outdoor Velcro and a couple of bolts. Diesel$ Live$ Matter. ⛽ï¸ðŸ›¢ï¸ðŸ‘¨â€ðŸ”§ðŸ§°âš™ï¸ RED, WHITE & BOOST! 🇬🇧
Post #665049 17th Nov 2017 12:11pm
Of course not. As with so many of these things, the chances of anybody actually checking are slim to none but the regulations do provide more detail for those that are interested. Darren
Post #665064 17th Nov 2017 1:06pm
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
I seem to recall there was a height restriction for front number plates for cars but this was not included when the regulations were re written in 2001. I have never known anyone being prosecuted for an offence where the number plate was reasonably visible only for failing to have one, having re arranges the spacing, colouring in a fixing screw to make it look like a full stop or having pre 1973 black and silver plates on a later vehicle. I also think you could argue that placing your plate on the front grill would effect the running fo the vehicle and so it couldn't be considered a reasonable vertical surface.
Post #676243 6th Jan 2018 12:17am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Some years ago I had a Series 2 that had a 90 front end and the number plate on the front of the bonnet. The local police didn’t like that too much. I was pulled over for something else and one officer commented .. “.. and sort out your front number plate. What do you think I’m driving? A Censored helicopter?â€. Needless to say it remained like this until I sold it.
I’m a little more compliant these days Very Happy 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #676246 6th Jan 2018 12:49am
I never used to have one...motorbikes don't need one.
However that was before NPR cars, even going to a shoot on Boxing Day, there was an unmarked BMW parked in Leek with an NPR camera discretely fitted on the rear bumper.
It's easier to just have one.
Post #676277 6th Jan 2018 9:14am
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
Mine is on the front of the cage above the windscreen; vertical and less likely to get caked in mud or knocked off when of road.
I've not had any issues with MOTs or anything and it wasn't mentioned when I was stopped by the police and recommended to fit rear mud flaps Embarassed
Post #676304 6th Jan 2018 11:19am
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
My issue with the bumper mounting is the number plate is slightly proud of the standard bumper so annoys me when I clean it.
Think I may just trim it down a bit.
Post #676671 7th Jan 2018 7:39pm
JAY BOY
Wales
Ive got mine the same as the bowler picture.
Not been pulled but i don't think you would be pulled in a defender if you didn't have a plate. Laughing
Post #676675 7th Jan 2018 7:44pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I had my number plate like this for many years it was trimmed to just fit the opening flap
Post #676679 7th Jan 2018 7:48pm
steveyorks
One of the most stolen cars in Britain and you don't think you would be pulled for not having a plate? I think its a perfect excuse for stopping you to check its yours!
Post #679033 16th Jan 2018 10:29pm
roel
Fit a rollcage. Smile
 Roel
2003 90 Td5 (2009-now)
Post #679128 17th Jan 2018 8:21am
miker
Nope. I'd have to see a traffic officer on the road to get pulled Rolling Eyes
Post #679216 17th Jan 2018 12:46pm
Page 2 of 3 <123>
