Home > Maintenance & Modifications > Rear work lamp |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Basically it needs to be on a separate illuminating switch to be legal. Whichever way you do it however it's best practice to use a relay.
Many people wire them in through a three way switch so you have Auto (on with reverse) Off On (manual) If going led then a relay isn't needed 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 17th Dec 2017 2:13am. Edited 1 time in total |
17th Dec 2017 12:00am |
Scenelight is a good option. Ray (mk1collector) on here has just fitted one. See his excellent thread > http://www.defender2.net/forum/topic17615-765.html 2002 90 Td5 Station Wagon
17th Dec 2017 12:02am |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1833 |
If I understand you right, you're talking about having your work light switched on/off when the vehicle is put in/out of reverse gear?
I think that would be quite restrictive and maybe a bit impractical. Better to find an alternative power source and allow it to be switched independently. I'll be fitting a scenelight shortly I think, and I'll try and gave that switched at the light. I currently have one switched from the front dash, but I ran power up the A pillar and along the side of the roof (I had the headlining out at the time anyway). |
17th Dec 2017 12:03am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1820 |
Another vote for the Scenelite
Click image to enlarge I've set mine up to be operated by a switch on the steering column cowl, so it's easy to reach should I need it whilst reversing. Was easy enough to feed the wires up the a pillar and tuck behind the trims to get to the back door. I think www.exmod.co.uk have them on offer at the moment 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
17th Dec 2017 12:32pm |
Scenelite here!
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I wired mine with two switches, uno on the cubby box and the second on the rear, closer to the Left loudspeaker. Below you can see the electrical diagram. With the cubby box switches (ON-OFF.ON) you can select: 1. Rear lamp ON 2. Rear lamp OFF 3. Rear lamp ON with reverse Click image to enlarge with the rear one you can switch on the lamp Click image to enlarge and, yes, very good quality, very nice style and powerful.... here the wiring schematics Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Dec 2017 10:40pm |
