Home > V8 > 90 V8 ragtop value?
Page 2 of 2 <12
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
New chassis is about 3.5k + labour, cross member around 200 + labour 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #663672 12th Nov 2017 12:46pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Thanks Kit Thumbs Up
Do you have an idea of the labour cost?
I’d guess that there would be some savings doing both at the same time but even at a labour rate of £50 per hour, I’m guessing the labour for a chassis / x member swap would be £5,000?
So parts and labour would take the work to circa £9-10,000?
Post #663677 12th Nov 2017 1:07pm
Kit
It's really one of those how long is a piece of string items, the problem is, if a chassis needs replacing there's a good chance that it's going to be a tough job with broken/seized bolts and replacing/repairing other items while it's in bits.
The bare minimum would be a weeks work though i'd say, you'd probably get a discounted rate on the labor since it's a big job, i'd factor (depending where you are in the world and who you use) 60 hours (two guys) at £35 an hour - £2.1K.
The rear cross member is a part of the chassis, so you would do one or the other, it just so happens to be probably the worst designed part of it! 1993 200 Tdi 90 CSW
Post #663687 12th Nov 2017 1:49pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
A new galvanised chassis from Richards is less than half that. Typically around £1500 for a 88in Series and a bit more for a 90.
Post #663709 12th Nov 2017 3:47pm
Kit
double post 1993 200 Tdi 90 CSW
Post #663718 12th Nov 2017 4:15pm
Kit
My quote inlcuded items that needed replacing during the chassis change, the bare chassis price at the time was £2400inc VAT, I don't know who the manufacturer was though 1993 200 Tdi 90 CSW
Post #663723 12th Nov 2017 4:23pm
Page 2 of 2 <12
