Home > Td5 > Cutting out, strange symptoms |
1. check battery earth follow the cable down to chases and transfer box make shore all terminal good and sound
2. check battery POS terminal good and sound 3. check main relay under driver seat, relay terminal can work loss Click image to enlarge Last edited by dorsetsmith on 30th Oct 2017 11:38am. Edited 2 times in total |
30th Oct 2017 10:35am |
As it sounds like it's been turned off, a faulty switch on the end of the ignition barrel is a good possibility. Darren
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2075 |
I had a similar issue on my old 90, turned out to be a corroded main battery earth, fitted a new one fine ever since.
30th Oct 2017 11:31am |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
I saw in this thread http://www.defender2.net/forum/topic56773.html (about a puma) that if the trip doesn't reset to zero it's unlikely to be an earth/battery issue and is more likely main relay or ignition switch, is this true for a TD5 as well?
1st Nov 2017 2:26pm |
