Home > V8 > LS3 |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Contacted a company called TopHat, who have two sites in the US and one in Holland, to see what a Euro price might be on an LS3 conversion. It seems they only do a full conversion, here's what they offer. (Note this only offers a manual transmission, no Recaros, no sound upgrade and no leather trim etc):
LS3 drive train upgrade includes: - Engine Assembly, LS3 Long Blk - Oil Pan Assembly, LS2/LS3 Style - Harmonic Balancer, Pioneer LS3/Truck - Type, 8 Rib, 10% Overdrive Black - Intake Manifold Assembly, LS3 Style - Thermostat, 186 Degree - Billet Water Neck foThermostat - Water Pump Assembly, Camaro Style - Alternator - Power Steering Pump Set, Camaro - Coil Pack Assemblies, LS2/LS3/LS7 - ECM, GM E38 - Wiring Harness, LS3/7 58T - Flywheel - Dual plate clutch - Air Filter, K&N RC-4680 LS14in - Coil Cover Kits, LS3 Black - Starter, All LS inc shield - T56 Magnum 6 speed manual transmission - Stainless steel fuel lines - Bosch Fuel Filter Assembly - High flow fuel pump - Holley Fuel Pressure Regulator - Stainless steel braided fuel hoses - Upgraded Tophat transfer case - Limited slip differentials front, rear and in the transfer case - Upgraded heavy duty halfshafts, CV joints and drive flanges - High performance AP front and rear disc brake upgrade for 18" wheels - 364mm vented and grooved discs with 6 pot calipers in front - 330mm vented and grooved discs with 4 pot calipers in rear - Stainless steel brake lines - Stainless steel fuel lines - Tophat oil filled engine mounts to eliminate engine vibrations - Tophat transmission and transfer case mountings - Heavy duty anti roll bars - Upgraded Tophat cooling system - Tophat custom oil cooler - Tophat custom transmission cooler - Power steering cooler - Sanden AC compressor - High performance fuel system - Custom stainless steel full exhaust system with headers - Improved steering geometry - special KONI/TOPHAT shock absorbers - Air suspension or coil springs - Upgraded thermal and accoustic insulation - Custom air intake - 18" wheels of choice - Cooper ZEON LTZ 285-60-18 tires - Rear Radius arms - Front radius arms - A frame - Panhard rod - HD Steering arm and track rod - New steering box - Disco 1 drop arm - Upgraded steering damper - 30mm wheel spacers - Front drive shaft - Rear drive shaft - Upgraded swivel housing with upper and lower swivel pin bearings - Front and rear stub axles - Upgraded front and rear drive flanges - Front and rear wheel bearings - Front and rear flanges - Speed pick up sensor - Upgraded transfer case with sleeved casing and limited slip diff - Upgraded front and rear pegged differentials with limited slip diff - All bushes, rubbers, bolts, nuts, washers, etc. Here's their price €95.000,00 Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
25th Oct 2017 3:35pm |
You can't fault their work or their pride in it though. Here are some shots they sent me:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
25th Oct 2017 4:08pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Ouch that price! But when you see this photo, you realise what's involved!!
James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
25th Oct 2017 9:19pm |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
Very detailed conversion, whopping price tag tho
2nd Nov 2017 6:00pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
worth a look... credible outfit by the looks of it...
SKIP https://www.defender2.net/forum/topic83242.html |
2nd Nov 2017 6:54pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
I love the TopHat stuff EXCEPT I hate KBX front ends, they are just hideous,but I suppose people need to know that your car is 'bespoke' somehow I'm not much for the logo on the steering wheel either, a bit naff.
Other than that, the ragtop is perfect, I like the alloys on it too. Hats off to them. |
2nd Nov 2017 7:10pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I like some of the KBX front ends but I don't like that one with the mesh in it, I like yellow on a ragtop, not so much for a hardtop though 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
2nd Nov 2017 8:16pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6265 |
air suspension too.
I personally would have preferred the mirror arms to remain black......... Looove the 110 |
3rd Nov 2017 1:49pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2872 |
Listening to these going through the gears, manual is def the best option Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
4th Nov 2017 10:11am |
