Home > Puma (Tdci) > A little bit of unleaded in a 2.2 puma tank. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7693 |
How much petrol in the tank do we think you can get away with? 50%? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
17th Oct 2017 1:52pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Think 50% might be pushing it,
I wouldn't like to run it above 30%? I think you might be in pump damage territory? Could be completely wrong though.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
17th Oct 2017 2:38pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2075 |
Same, I double and triple check. I almost always follow the line back to the source to make sure its coming from the right one! Luckily me local garage has the fuel type written on the pump handle and petrol/diesel pumps are segregated. Didnt know throwing some unleaded in the tank was good for emissions! I knew people did it in winter but thats about it |
17th Oct 2017 2:50pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
You could always Siphon some (or all) of it out...
Thought I'd check... just may be LR have fitted an anti-siphon (gadget / ball) to the Filler Hose, I was fairly sure they hadn't (Security... ) and sure enough (on a 2.4 Puma) you can get right down into the Tank with a standard length of garden hose. Now the reality of doing this under the 'typical circumstances' of putting in the wrong fuel, are not as straight forward as it first appears, I'm sure you can't siphon on a garage forecourt, and even if you did the 'push of shame' around the corner, you are then faced with the what do I siphon 40-50 + Lts in to... more on a 110, assuming you have really 'phased out' while filling up. Dilute down as has been said, but this will not change the % mix in the fuel lines, until the new mix runs through, if it were me I'd be tempted to siphon out as much as possible, as soon as possible, (round the corner) then maximising the Diesel to Unleaded ratio, doing the sums in my head as I went... Also top up with the higher quality Diesel as this is claimed to have improved Lubrication Qualities. Some Breakdown Services cover this 'mishap'... (with Green Flag its standard on all Levels of Cover except Rescue only) 150,000 Cases a year apparently, so you are not alone... Good Luck Dobby Siphoning a Puma... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
17th Oct 2017 2:55pm |
You are probably ok with less than 10%, but seems best to keep topping up and diluting. Common rail diesels do not like petrol as I understand. Also read below.
Eric http://www.forecourtassist.co.uk/help-advice-for-misfuel.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Oct 2017 3:27pm |
Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 |
Thanks. I added 70 litres of posh diesel ontop of it, so syphoning that lot out isn't something i'd look forward to. Seems to be running ok sp far. Have added a 2 stroke oil too just to keep the pump lubed up nicely. on the plus side, even with the posh diesel in, it's running really smoothly. Like having a good splash of miller diesel power in there. |
17th Oct 2017 4:10pm |
So you've found your new 'Power Mix' then.
What's the 'take away' from this...(if as you did) start with < 10Lts of Unleaded, into a Tank that presumably needed filling, would you do the same again... 'drown it' in Diesel, or would you be tempted to get it out... Good to know that a little looks to be 'tolerated' (and progressive dilution can only help) SKIP https://www.defender2.net/forum/topic83242.html |
17th Oct 2017 4:31pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 907 |
AFAIK Phil baylis still runs about 5% unleaded in his well tuned 90 TD5. So it is a known thing to make more power but not enough to make me want to try it though
17th Oct 2017 4:59pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Older inline type injection pumps are no problem, rotary pumps will sieze bearings and electronic are a gamble. I ran Mercedes trucks when they used Bosch inline injection pumps and the handbook mentioned a 50% of unleaded in severe weather but did add in some countries including UK was an offence under C&E regulations.
17th Oct 2017 5:39pm |
Kerosine was another alternative to prevent waxing, Adding Kerosene (parafin) is an offence, because there's no duty paid on it.
Petrol isn't a problem legally as you've already paid the duty on it. |
17th Oct 2017 6:35pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Now my question is will adding a bit petrol be beneficial to the 2.2?
I have heard ppl putting two stroke oil and stuffs in |
29th Oct 2017 3:11am |
HongKongUKDefender Member Since: 17 Dec 2017 Location: UK and Hong Kong Posts: 8 |
On a reverse note I put about half a litre of diesel into my old Saab 95-5 T and not a bit of smoke a few years back. Did fill it after every 50 miles thereafter.
{btw a Defender 110 owner) |
5th Jan 2018 12:31pm |
