Home > Technical > TD5 OBDII port wiring |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
https://en.wikipedia.org/wiki/On-board_diagnostics
scroll down for pinout 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
9th Oct 2017 1:26pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
Are you building your adapter or re-installing it back to original?
If the adapter, then you can use this socket from the site shop: https://www.disco3.co.uk/shop/obd2-socket-housing-p67.html If you want the original the LR part number is YPC107920 (about £3 from a dealer before any discount) Pinout 4 - Ground (Black) 5 - Ground (Black) 7 - K-Line (Pink) 8 - Alarm (Orange with Light Green) 16 - 12V Battery (Purple with Brown) This is viewed from the connecting side not the wire side. I can supply the terminals bare or with wire (can do other colours on request): https://www.disco3.co.uk/shop/obd-socket-c...e-p46.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
