Home > Puma (Tdci) > What fuse is the front DRLs?
Merlin
Is there a single fuse that can be pulled to disconnect the DRLs? For one of the late Defenders.
Merlin
Post #649615 11th Sep 2017 5:54pm
ericvv
Strange question really. DRLs are always a aftermarket installation, never factory, not even on the very last Defenders.
So a fuse will be the one that has been installed with the system, if a fuse has been installed at all that is.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #649648 11th Sep 2017 8:17pm
Merlin
Blindingly obvious now you mention it.
Thanks,
Merlin
Post #649790 12th Sep 2017 11:05am
X4SKP
Hello Merlin
My set came with its own wiring loom with an integral in-line 2Amp Fuse.
Typically aftermarket 'kits' assume the Battery is under the bonnet...not under the seat... Exclamation
so I imagine that the looms come up short for most.
I moved the 2Amp Fuse position to the Battery, using a Blue Sea Terminal Block...
 SKIP
Post #649794 12th Sep 2017 11:18am
