Home > Td5 > Bonnet Alarm Switch Position
V8GPC
Can anyone upload a photo of the bonnet alarm switch and where / how it makes contact with the Td5 all aluminium bonnet.
My Defender had a Puma bonnet; but the buldge touched the roll cage when opened; and it had hiddious stripes. So I swapped it with a late Td5 one; but the alarm switch doesn't seem to be in the correct position to touch the bonnet; the bracket looks like its adjusted as far as it can go.
The Puma bonnet had a rubber bung attached (diy job) that touched; the new bonnet doesn't have anything.
Is there an angle bracket or something?
Doesn't hepl that my switch is knackered too and gets stuck half way down, so I have not got a new switch ready to fit.
Post #644317 16th Aug 2017 6:58am
dorsetsmith
https://forums.lr4x4.com/topic/97598-bonnet-alarm-switch/ TD5 and same place from 07 onwards
ABU710160 RHD
Post #644328 16th Aug 2017 8:14am
V8GPC
thats good info, its the later style bonnet though that i'm looked for a photo off.
My Defender is a 1998 so should have had the sytle in the photo; but i now has the later type (not Puma)
Bracket and switch fitted from original.
Post #644353 16th Aug 2017 10:08am
dorsetsmith
fixing position is same but fixing bracket part number changes Question
from 2001 to 07 part number is the same the only diffractions is RHD to LHD
Post #644356 16th Aug 2017 10:24am
V8GPC
makes sense now; must be a taller bracket... many thanks Bow down
Post #644397 16th Aug 2017 12:37pm
V8GPC
later bracket fitted and all sorted.
Side by side the two brackets are very similar looking, just slightly longer plate where the holes are and they sit lower.
If anyone else searches in the future - confirmation! Bow down to dorsetsmith
Post #646556 27th Aug 2017 12:17pm
