Home > Td5 > Bonnet Alarm Switch Position |
https://forums.lr4x4.com/topic/97598-bonnet-alarm-switch/ TD5 and same place from 07 onwards
ABU710160 RHD |
16th Aug 2017 8:14am |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
thats good info, its the later style bonnet though that i'm looked for a photo off.
My Defender is a 1998 so should have had the sytle in the photo; but i now has the later type (not Puma) Bracket and switch fitted from original. |
16th Aug 2017 10:08am |
fixing position is same but fixing bracket part number changes
from 2001 to 07 part number is the same the only diffractions is RHD to LHD |
16th Aug 2017 10:24am |
makes sense now; must be a taller bracket... many thanks
16th Aug 2017 12:37pm |
later bracket fitted and all sorted.
Side by side the two brackets are very similar looking, just slightly longer plate where the holes are and they sit lower. If anyone else searches in the future - confirmation! to dorsetsmith |
27th Aug 2017 12:17pm |
