Home > Puma (Tdci) > Puma Maintenance Schedule - Definitive Guide
The Fox
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
So my pride and joy MY14 90SW is finally out of warranty and fresh out of the dealers after a month at the body shop being sorted. I thought it would be good together to put together a definitive routine maintenance schedule, in addition to the usual A & B services.
What do people do as a routine job, how often and on what parts (grease, oil, level-checks etc.) I'll tie it all together on a worksheet.
Post #642357 7th Aug 2017 11:33am
The Fox
In addition to this, that is...
I'll start:
50,000 Miles :: Replace axle and transfer box oil
100,000 Miles :: Replace gearbox oil
Post #642361 7th Aug 2017 11:38am
ericvv
Well, if it is your pride and joy, do you really want to wait that long to replace the gearbox and transfer box oil? Shocked
I'm not impressed with this Land Rover schedule where you can wait until a next life before replacing gear/transfer box and axle oils. Or replace the coolant fluid only after 200.000 km. Shocked Common sense tells me otherwise. Whistle
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #642365 7th Aug 2017 12:00pm
X4SKP
Hello The Fox
In addition...
I completely agree with ericvv...
The Maintenance should match the work tackled, but even if this is predominately road use, there is a lot of mechanical movement through the Transmission and Running Gear, swapping out all these with good quality Oils and Grease, at 50% (or sooner) than the recommended LR Schedules, is a wise move in my opinion.
To be fair to LR, they do advise a significant reduction in operation time between maintenance with 'Arduous Usage'...
Close Up...
Good Luck...
 SKIP
Post #642378 7th Aug 2017 1:34pm
V8GPC
been staring at the last picture for ages, did anyone else notice its a series 2 rather than a Puma?
Took me a while though Whistle
Post #642425 7th Aug 2017 6:14pm
zsd-puma
Eric
Don't be silly you'll have to replace them long before then due to leakage anyway. Laughing
To be fair the Japanese have been using sealed for life coolant for decades. And Land Rover do specify much lower change intervals if you work the vehicle hard in dusty/wet conditions or extremes of temperatures. It never hurts to change more often than needed, although it may just be a waste of money.
Post #642455 7th Aug 2017 7:58pm
The Fox
So I started writing this for my own reference, but if it's useful for anyone else I added a disclaimer and used your input:
Post #642975 10th Aug 2017 4:56pm
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
These look great have you got a PDF at all? @tab.travels on instagram
Defender 130 2.2 TDCI
Defender 90 TD5
80" CCV Trialer 4.6 V8 (14CUX)
Stage One V8 109 - 3.5 V8
Stage One V8 109 - 4.6 V8 (GEMS) - in progress
Range Rover L322 4.4 TDV8
Freelander 1 2.0 TD4
Post #722270 8th Aug 2018 3:37pm
Ianh
I’ve been looking for a 2.2 puma service schedule PDF as a nice way of recording the service work I undertake, and really like the Defender2.net one above. Was a copy ever posted as I would really appreciate a copy to use myself.
Also is there a landrover one for the 2.2, as per the 2.4 one posted at the beginning of this thread. I have searched but can’t find one here or on line.
Post #795782 29th Sep 2019 12:51pm
The Fox
Sorry for the delay here, PDF of what I use is attached.
Hope it's useful to someone else.
https://www.defender2.net/gallery/albums/u...hedule.pdf
Post #797273 8th Oct 2019 3:53pm
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
Great - very useful guide.
Post #797277 8th Oct 2019 4:56pm
Ianh
Mr Fox... you are a star...many thanks. Thumbs Up
Post #797283 8th Oct 2019 5:23pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Very good. Would it be too much to ask for the "source" (Excel? Word?) so I could change some details for my own needs?
Post #797299 8th Oct 2019 6:54pm
Ianh
macfrank , you can open a PDF in word and it will auto convert into word format.
To do :-
Download PDF file , Open Word , click on file, then open , then computer . Select directory in which downloaded file resides , a pop up box appears and in the pull down box above "file" and "cancel" buttons ( lower right hand side of pop up box) select PDF as file type. All pdf files now show. Click on the puma schedule pdf file you downloaded to highlight it and then click on the open button. It will now convert to word and you can edit and save.
That's what I just did Smile
Post #797583 10th Oct 2019 4:02pm
JOW240725
Very useful, thank you Thumbs Up James
Instagram @suffolk_rovers
Post #797589 10th Oct 2019 4:44pm
