Home > Maintenance & Modifications > Horn. (Upgrade) |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 402 |
One of the horns on my Puma has failed, I could take it in under warranty but I'm looking at upgrading the horns to something that will last a bit longer and be a bit louder.
Are the horns part of the alarm system? I quite like the sound of Stebel Nautilus. Looking on the website, the current draw is 18amps which I'm guessing is a bit to much to pull through the existing wiring for of the horns? The other option on the Stebel site are the TM80 Magnum which only have 6amp draw but are very close on sound output. What other horns have people used? I want to replace the existing horns and use the factory loom so current draw can't be to high. (Does anyone know the draw on the standard horn?) Cheers Yan |
17th Jul 2017 10:49am |
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 |
I like the Nautilus, I have it on my motorbike and my RRS, not yet installed on the Defender.
Both installation with a relay, will be the same on the Defender, a bit more work but I think is better and safer. On the RRS I did not disconnect the original ones. |
17th Jul 2017 12:51pm |
My Mini has had air horns since about 2002, but i think the horn has a relay as standard.
If however you have one of the upgraded headlamp wiring harnesses, you can just pick up the battery feed from that harness and relay the horns in the same way the headlamp harnesses do. It's not that much more work. |
17th Jul 2017 4:39pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 716 |
I have two tone air horns on my 90 and they are very loud, and a distinguishable tone too. BORG - Bucks & Oxon 4x4 Response Group
17th Jul 2017 7:33pm |
Or another option
https://www.hornblasters.com/ |
18th Jul 2017 12:42pm |
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 |
I could watch that all day....
18th Jul 2017 12:48pm |
Where would you put the air tank and where would you fit the horn?
18th Jul 2017 7:10pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
next to the chassis rail would be my choice - like where hey used to have the fuel tank or in the massive void in the rear arches Mike
18th Jul 2017 9:28pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Nathan K5LA is what you really want! You don't need them however, but you want them! Trust me I've used them for years!
20th Jul 2017 11:31am |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 |
And this is what a K5LA sounds like.....
A mate has one fitted to his Western Star, no recording of it yet, sounds great in the tunnels. The videa has a great echo to it. |
20th Jul 2017 10:40pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
Can anyone shed some light on the difference between:
https://www.mx5parts.co.uk/stebel-nautilus...-3356.html or https://www.mx5parts.co.uk/stebel-nautilus...-3364.html (Other than the price obviously) From what I can tell the main difference is the fundamental frequency with the truck horn operating at 300hz and the compact at 530hz If anybody has fitted one which one did you go with? Thanks Keith |
10th Nov 2017 1:10pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1829 |
Just resurrecting this, as I am looking at upgrading the horn. 1994 300Tdi - just one horn, by the intercooler, passenger side.
After I had the wing off recently, everything worked perfectly on rebuild except the horn. It's probably just wiring, and the unit itself is OK, but like some of the replies above I've often felt it was a bit insignificant, and a poor match to the car. Seeing as I'll need to go back in and look at it all, the time might be right for a change. I don't really want to stop folks' pacemakers, or pretend it's a train, just something a bit more respectable. I looked at the two links in the post above - they seem respectable enough. Any thoughts, or any alternative suggestions since this thread was last on the go? Cheers D Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
21st Mar 2018 9:17pm |
I went with the 300hz one and then ran a new cable direct from the aux fuse box so that the existing cable operated the relay. Its a tight fit behind the light cluster but fitted in the end.
It's not ridiculously loud and does sound better than the stock one. Keith |
21st Mar 2018 11:51pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Whilst in the O/S front wing of mine recently I discovered a pair of air horns and a compressor. However, the horn is rather too polite. It turns out that the air horns aren't working, so that's another job for the list... There is a bank of ~6 empty after-market relay bases in the engine bay so those need further investigation. The clocks change this weekend so a productivity boost is pending
22nd Mar 2018 10:50am |
