Home > My Defender > Alan |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Haha, I'm not sure being towed at that speed would be a good idea 2002 90 Td5 Station Wagon
6th Jul 2017 10:40pm |
Good stuff where did you mount the switch? 2002 90 Td5 Station Wagon
7th Jul 2017 3:41pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4940 |
get some photos up! This could be my next move at some point. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
7th Jul 2017 4:02pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
There isn't much to photo and I had to go to work after
The switch replaced the one blank one on the binnacle, right side bottom edge.. I routed it as Grafty said.. out of the battery box, along the chassis leg and up the bulkhead.. across to the drivers side and in through the grommet at the back of the binnacle... I managed to not take the dash top off and fed the positive up the side behind the heater controls.. the earth on the other side I have fixed to the bolt holding the door stay to the bulkhead... I haven't made any connections yet and I need to find an ignition live somewhere round the dash... I have booked the screen to come on Thursday, this I bought off Ebay £180 inc fitting at home 1993 200Tdi Defender 90 |
8th Jul 2017 2:00am |
my dad tapped into the ignition barrel its self when we wired in the spot lamps. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th Jul 2017 2:05pm |
Cheers Procta.. I will have a poke about..
here is the switch.. Only snag is the instructions say two green to outside pins and yellow to the middle.. whereas the colours are reversed on mine.. I have emailed MC to clarify.. Click image to enlarge 1993 200Tdi Defender 90 |
9th Jul 2017 10:39am |
Looks neat there 2002 90 Td5 Station Wagon
9th Jul 2017 11:37am |
Thanks... I think I have dislodged the speedo cable the needle is wondering about a bit.. Il didn't unplug it but I did pull it about a bit getting my little paws in to pull the wires through... 1993 200Tdi Defender 90
9th Jul 2017 11:44am |
Yeah it may just be caught up on somthing. Too sharp a bend can slow it down and cause needle wobble 2002 90 Td5 Station Wagon
9th Jul 2017 12:02pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Great progress on the wire loom Profyaffle and a neat switch, looks as if its always been there 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
9th Jul 2017 10:09pm |
whilst I was making the ignition live connection to the heated windscreen loom I added a couple of extra bits..
LED lighting in the footwell and a voltmeter, both controlled by a switch.. I used existing spare feeds in the dash with the old style bullet connectors. 1993 200Tdi Defender 90 |
11th Jul 2017 1:11pm |
Nice! 2002 90 Td5 Station Wagon
11th Jul 2017 4:41pm |
neat little upgrades there Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
11th Jul 2017 5:22pm |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 405 |
Every time I see this thread I can't help thinking of ...
https://www.youtube.com/watch?v=F0BfcdPKw8E |
11th Jul 2017 10:52pm |
