Home > My Defender > Proctas Defender 300TDI |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4942 |
Also tonight there, some more stuff on order from Ebay, Gearbox mounts, a decat pipe, a number plate light, fan belt with tensioner, ( more info on that to come)
I did toy with the idea of buying my disc setup upgrade, but id rather do some more research on the rear side of things 1st as well as replacement hoses too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
5th Jul 2017 9:34pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
What will you be doing with the brakes then?... 1993 200Tdi Defender 90
5th Jul 2017 9:45pm |
I will be switching them to vented at the front, and upgrade the rears, I do have a problem somewhere across the board. So i might as well just upgrade while i have the option to do so. With me doing mainly motorway miles i want the system up to scratch. The A19 what i go on, is wacky races at times! So i need the stopping power, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
5th Jul 2017 9:49pm |
Good luck with that... I shall await further updates on it and the rest of your improvements.. 1993 200Tdi Defender 90
5th Jul 2017 9:53pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
I switched to vented front and 110 rears on mine. Made a nice improvement in stopping power 2002 90 Td5 Station Wagon
5th Jul 2017 10:11pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Sounds like you're getting ontop of it mate 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
5th Jul 2017 10:32pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
Could be, I've heard him speak of Matt Neal. Alex is currently with the Mobil 1 HSV Racing Team. Pickles. |
5th Jul 2017 11:02pm |
what is the difference with the 110 setup vs the 90 rear wise. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2017 6:03am |
yeah since I got the mot out of the way, been very expensive that was. Lost 450 on welding which was only worth about a 100 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2017 6:06am |
Matt neal has been in the btcc for nearly 30 years, he has worked his way up from an independent team to a works drive. won the championship 3 times. But I think he has lost his spark now, your friend might have even worked with him too at some point. Some engineers do jump around. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2017 6:09am |
110 rear brakes are very slightly larger in diameter but the main difference is that the caliper is larger and has a larger piston for better braking on the rear.
The good thing is that it's a bolt on conversion and even with the extra power at the rear, the fronts still lock up before the rear. So it's still a stable and safe braking upgrade 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
6th Jul 2017 7:22am |
Rusty380 Member Since: 20 Jun 2017 Location: Nottingham Posts: 81 |
Nice progression, amazing how some of the small details make a big difference!
6th Jul 2017 8:27am |
thanks for that grafty, another Ebay search and an item watched Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2017 9:39pm |
yeah the little things make the difference, which you will see when you add those touches to yours. My dad isn't keen, he is more original, me I have gone for the more lux side of things, XS spec. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2017 9:40pm |
