Home > My Defender > Bankz' 2004 Defender 110 Double Cab Pick Up XS
Page 3 of 4 <1234>
bankz5152
Got a few bits done last night as well. LR seat rivnuts arrived too, well I should say rivnut. The ebay listing said x6 though one arrived. Can't say im best pleased considering the next available delivery date is bloody Tuesday! That said one has been fitted.
Passenger seatbox Anderson Connector -
You can see why I want the corner protectors, I don't like that you can see the seam!
While in possession of my mates very expensive rivnut tool I thought Id get on the the wing top plate. Chose rivnuts as I want to be able to remove the plate in the future when I fit a KBX Hiforce intake, yes it will be just for show but it looks nice! :p
Did give it a wipe down with some GUNK traffic film remover, the epsom green is just such a nice colour when cleaned up!
Much better!
Used stainless socket heads on the other side, to keep the black/stainless theme going
Got more stainless bolts en route for the other side too. Also ordered the SP LR stainless door thresh/carpet retainer for the rear, looks so good in the front the rear had to match!
Post #616492 13th Apr 2017 10:57am
L110CDL
You are making great progress there Bankz Thumbs Up Just wish i had some free time to catch up on some small jobs, never mind that day will come Laughing 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #617068 15th Apr 2017 8:54pm
bankz5152
I tried out some G4 Scratch Remover and bloody hell I'm impressed.
Close ups, roll over damage is practically gone!
I did get a bit carried away and ended up doing half the car... Used a waffle sponge with a drill attachment, then jet washed it again with a Karcher spinning brush attachment (which is fantastic for cleaning, It's really quite brilliant), dried it and waxed it with another drill sponge. Got to say I'm bloody impressed with how it came out! Going to do the rest of it this week!
Post #617626 18th Apr 2017 10:42am
bankz5152
Continuing with the G4 scratch remover and some polish! Did the other side last night
Forgot to take shiny pics Embarassed
Refitted the acoustic cover to the engine, been a LONG time since I've had one of these fitted
Going to leave it on for a couple weeks see if it actually makes a difference in noise levels....
In other news the second row/rear stainless carpet retainers arrived, currently not fitted as my carpet was wet :rolleyes: so letting that dry off first.
Brake master cylinder also arrived, genuine LR as described, or at least as far as I can tell...
Plus off to France off roading in a couple weeks! Bought a new SLR Lens for the occasion! :D
Post #617892 19th Apr 2017 11:34am
L110CDL
That is impressive Bankz, nice shine to it, will have to learn to do mine one day, looks an easier way than doing it by hand Whistle 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #617983 19th Apr 2017 8:47pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Inspiring thread Thumbs Up My confidence has been writing cheques that my abilities can't cash for years.
Post #618042 19th Apr 2017 11:33pm
bankz5152
Big update! Fitted the SP LR stainless door threshes all round, a lovely improvement. Sprayed the rear with two coats of acid etch to stop and potential galvanic corrosion
Then it was off to France for some off roading in the sand! Havnt got that many pics as the day was fraught with breakdowns, mainly springs dislocating and one blown diff (mine Whistle )
One mishap!
Well recovered though, with no damage.
Both shot out the rear!
Video from just after my front diff blew, I thought the bang was a spring relocating Sad
Does make an awesome noise though Cool Smile
Remains of the diff -
Luckily a had a spare diff sitting at home! and the splines/shafts/CVs where undamaged, all repaired and running now Very Happy
Sadly I did have a couple flat spots when at max revs in 2nd, turned out to be a tiny boost leak at the EGR blank where I tapped in my boost gauge! All solved now thanks to Jose at TD5inside! Who also retuned the 110 for an uprated MAP sensor and a little more power (only a bit a promise Whistle )
Early estimates put it at around 195bhp and 460nm torque (to be confirmed on a dyno soon enough)
It really does have bundles of torque and almost zero turbo lag. Its brilliant!
Post #626348 23rd May 2017 3:56pm
JOW240725
Is it just me that can't see any photos in this thread today? Confused James
Instagram @suffolk_rovers
Post #626361 23rd May 2017 5:14pm
bankz5152
Not sure? I can see em on mobile and my pc
Post #626380 23rd May 2017 6:06pm
JOW240725
Got them now, great pics! Thumbs Up James
Post #626420 23rd May 2017 8:21pm
bankz5152
Did a couple bits over the weekend.
Cleaned my rocker cover with some plusgas and scotch brite, came out rather well I think!
And insulated all my A/C pipes with some pipe insulator from B&Q for all of £2.50 and a roll of foil tape for £3
Not exactly pretty but it has made a difference! The A/C is actually cold now but does need to be re-gassed!
Main issue is LR in their wisdom thought it would be a good idea to run the A/C pipe so close to the main coolant hose it actually touches! There is more than enough space in there to have to pipe run away from the coolant hose!
Post #629140 5th Jun 2017 3:53pm
Enid_Puceflange
I'm loving the look of your Dcpu , and the work you are doing to it.
Thanks for the inspiration for mine Thumbs Up
G My confidence has been writing cheques that my abilities can't cash for years.
Post #629175 5th Jun 2017 5:08pm
bankz5152
Had a brilliant weekend out on the Salisbury Plains! The 110 did brilliantly with zero faults bar a cracked headlight, that I JUST fitted!
Not many other breakages either, a Disco blew a diff and the other Disco blew the HG on the way home but thats it.
110s first wade! I went rather slow as no snorkel...
Check that flex!
Fun in the mud
Not been this muddy before!
Nice pic Very Happy
Testing the water
Wasnt even the deepest point -
Very deep water (same as above) so we attached a safety line to my 110 just in case, it was needed.
No smoke no poke!
Bit of popcorn
Post #633866 27th Jun 2017 1:18pm
L110CDL
Great you had a good time Wink been there twice now, once wet like you and the other time dry as a bone, both good experiences Very Happy thanks for the pics and the tubes Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #634253 28th Jun 2017 9:24pm
bankz5152
Yeah it was a great trip! Ive been before in my 90 but waant as fun haha
Cleans up nice tho ay!
[URL=][/URL]
Quick wax
[URL=][/URL]
Raptor cleans up well
[URL=][/URL]
Post #634317 29th Jun 2017 9:02am
Page 3 of 4 <1234>
