Home > Puma (Tdci) > Heavy Clutch PEdal |
hossegor Member Since: 05 Feb 2012 Location: Frankfurt Posts: 19 |
i notecid that the clutch pedal on my Defender is very stiff and hard to push down. Even compared to the other landys i have driven.
i would like to do the a clutch pedal mod, i have read that replacing the pedal/spring with one from the 300 tdi would help.(part nr ANR5311) has anyone done this mod? heres a thread for the td5 , i am just not sure if this also works for the puma..http://www.defender2.net/forum/topic6616.html |
14th Mar 2012 12:17am |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1867 |
A company called redbooster do an additional servo kit and it makes a hell of a difference 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
9th May 2017 9:16pm |
raul Member Since: 11 Jul 2015 Location: Lima Peru Posts: 1 |
A friend changed 3/4 pump with a 5/8 pump and result is excelent
1st Jul 2017 5:50pm |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 |
Thanks for your reply but as I don't understand could you please explain what that means.
Cheers Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
3rd Jul 2017 9:27am |
Master cylinder bore i think.
There is also a revised slave cylinder which makes it slightly lighter, but i'm not sure when it bacame standard fit on the production line. Mine with all the latest bits is certainly heavier than a modern car, but it's not worse than any other Defender i've driven. it could be that some of the pivots in the pedal box need a drop of oil? |
3rd Jul 2017 6:31pm |
Could you get the type/brand of the modified pump? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
8th Jul 2017 11:08pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2240 |
As far as l know The tdci already has the "lighter clutch pedal spring" fitted as standard.
All the tdci's l've driven have had a fairly light clutch, certainly better than my TD5 (before l fitted the spring mod) If your tdci has a heavy clutch l would think it's faulty/worn close to the limit. |
21st Jul 2017 4:04pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3463 |
I freed my 130 off by using much penetrating oil last week. It's come back all 2017 easy rather than 2012 sticky! 1951 80" S1 2.0
21st Jul 2017 9:17pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Any one got any more info if this is worth doing as mine is stiff as **** Stew |
29th Jun 2020 7:33pm |
No news? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Jun 2020 7:39pm |
It doesn’t help being a short ass
29th Jun 2020 7:41pm |
Just googled red booster and found a great vid with it fitted to a td5 , I’ll lookin to it tomorrow
Click image to enlarge |
29th Jun 2020 7:45pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 678 |
LOF Power Master & their pedal spring! HUGE difference!
30th Jun 2020 3:50am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I quite like the fact its a heavy clutch peddle Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
1st Jul 2020 4:10pm |
