Home > Technical > After an engine rebuild |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 720 |
You forget about running in with modern engines.
Main points: Keep revs low when engine cold. No sudden stress or acceleration ( I Know- its a defender) Don't over rev when warm, keep to best gear without stress. Don't drive short distances regularly. As running in period progresses you can increase revs slightly, and a medium speed long run would work wonders. Fastish motorway run towards end of running in period best. All bits will be removed with filter change and oil change at 500 miles. Thereafter steady driving for next 1000 miles will pay dividends in the long run. Check with garage, but a 3000 miles oil/filter change might be advisable. |
1st May 2017 4:50pm |
Jonathan111 Member Since: 22 Jan 2015 Location: London Posts: 67 |
HI there, thanks, very useful, much obliged to you - what period should the running in cover, just the 500 miles?
1st May 2017 4:53pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Running in happens for a long time but it is generally considered that after the first 1000 miles then the engines full potential can be used.
Maximum economy and power is generally around the 30 - 50,000 mile mark. Although this is only a rule of thumb and differs between engines I would say the garage is a good one for demanding a 500 mile oil change 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st May 2017 5:39pm |
much obliged, thanks very much, all very useful, cheers, Jonathan
1st May 2017 6:09pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Varying loads. A nice country road, not a motorway drive
Keep revs low, but full throttle can (and should) be used |
1st May 2017 7:30pm |
1st May 2017 7:39pm |
cheers, much obliged, will take this advice, all best, J
1st May 2017 9:11pm |
