Home > Td5 > Manifold de-webbing |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
Geobloke, I'm interested in the Alisport manifold as I too have a VNT Turbo, is the any noticeable difference between the old design manifold and this one?
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
10th Apr 2017 5:00pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4405 |
Yes bog standard heat shield. |
10th Apr 2017 6:23pm |
Hi Will. I have a standard albeit new Garrett turbo. Hybrid would be the next step up. The difference of a standard turbo, full sized inter cooler, manifold and remap (generic so not tuned to my engine - defo need this next) is remarkable. The exhaust note seems a little sweeter ESP mid range. Low Rams are dogged by over fuelling hence the need for a retune. Once retuned I am hoping for great things. Physically speaking the differences are as CDN38 says longer header tubes and a shorter coolector. The important thing is that it is a straight swap incl. standard gaskets. I personally fitted this manifold for peace of mind and longevity. The Miffster is a keeper and will be our stead for many many years to come. |
10th Apr 2017 6:30pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Geobloke, I am in the throws of putting this set up on a friends truck. The Allisport exhaust manifold, and a VNT turbo. One thing I see first off is there is almost no room between the top of the centrifuge filter and the manifold, as well as the turbo. How do you get the filter cap off for filter changes? Certainly you shouldn't need to remove the turbo to do it, but it is really that tight! Not to mention one of the bolts for the cover is obscured by the manifold.
Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
1st Aug 2017 10:24pm |
I thought you got yours remapped buy an alive agent, not alive themselves? Ray
6th Aug 2017 11:21am |
