Home > Technical > Tow Bar |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I had a quick look under my 90 td5. The tow bar is connected to the support brackets for the fuel tank, so completely different than on a 200 tdi.
Click image to enlarge I am not sure you can see that on this picture. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
29th Mar 2017 10:21pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
Thanks Roel.. I thought that might be the case.. I may have to go to a garage and try some different ones out.
30th Mar 2017 1:15am |
I made a better picture:
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
30th Mar 2017 9:26pm |
Thats a great help Roel. I don't have any brackets other than the ARB bracket.. If I get time tomorrow I will have a trip up to the local indy garage and see if they have anything. Thanks again!
31st Mar 2017 12:08am |
Problem solved.. My local indy gave me a witter 110 Td5 kit to try and it fits... just need to get it painted now and sort a couple of bolts out for where the arms fasten onto the chassis as I don't have the tow eye bolts that should be re-used..
31st Mar 2017 12:02pm |
the tow eye bolts wont be expensive from Land rover, and they're galvanised.
31st Mar 2017 1:49pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2551 |
Do you have any photographs of your 110 towbar fitted to your Marsland 90 chasss please?
9th Jan 2018 10:22pm |
