Home > Td5 > Rear Heated Window Switch - Lights
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Currently with the lights on, the Rear Heated Window Switch glows green when it is off... as it should.
When I press the switch on, the light goes off. Which is a bit annoying, trying to find the switch in the dark to turn it back off. I am assuming it shouldn't do this?
Does the switch change colour when its on? or should it still be green?
Also can it be disassembled easily or is it a solid item? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #609573 15th Mar 2017 9:48am
grafty99
There is a small orange led to the right which should illuminate when the screen is on. As well as the light on the instrument cluster. Sounds like you have an earth problem somwhere Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #609622 15th Mar 2017 2:07pm
grafty99
And the green illumination should remain on with the side lights at all times Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #609623 15th Mar 2017 2:08pm
bogwert
Cheers Gratfy.
Ok I'll have a look at the earth. It illuminates fine when the lights are on and the switch is off. Chris
Post #609625 15th Mar 2017 2:11pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Can verify that what was previously posted is correct. Check grounding issues. Also the switch can be completely disassembled if need be. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #609638 15th Mar 2017 2:57pm
