Home > Td5 > Rear Heated Window Switch - Lights |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 |
Currently with the lights on, the Rear Heated Window Switch glows green when it is off... as it should.
When I press the switch on, the light goes off. Which is a bit annoying, trying to find the switch in the dark to turn it back off. I am assuming it shouldn't do this? Does the switch change colour when its on? or should it still be green? Also can it be disassembled easily or is it a solid item? Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW |
15th Mar 2017 9:48am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
There is a small orange led to the right which should illuminate when the screen is on. As well as the light on the instrument cluster. Sounds like you have an earth problem somwhere 2002 90 Td5 Station Wagon
15th Mar 2017 2:07pm |
And the green illumination should remain on with the side lights at all times 2002 90 Td5 Station Wagon
15th Mar 2017 2:08pm |
15th Mar 2017 2:11pm |
