Home > Technical > Cable Routing |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Depends the wire size and need (assuming a puma) without running along the gearbox tunnel you can get through the large grommets in the bulkhead its a royal arse of a job when i last did it Mike
23rd Feb 2017 9:29pm |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1008 |
Yes, well spotted Puma 110. There's 4 wires 3 probably 1mm & one 2mm..
23rd Feb 2017 9:48pm |
I certainly 2, around 2 mm through the grommet, although you could cut it to make it a little easier. Mike
23rd Feb 2017 10:32pm |
