Home > In Car Electronics > Alpine cde 133bt microphone not working |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6482 |
Are you sure it's in the correct socket as there are two on the back of the head unit. From memory it's the unlabelled one which is for the mic. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
15th Feb 2017 10:12pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2034 |
As Martin suggests, it's worth checking you are using the upper socket.
Click image to enlarge In this picture, the lower socket (REM) has a removable blank in it. Hope it helps. |
16th Feb 2017 9:40am |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
Many thanks for the quick reply guys.
I have the mic plugged into the hole, thanks for the photo reference. I have also removed the headunit to check for loose wires, which there was none, now time to check which part if any are faulty. |
16th Feb 2017 11:08am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
The microphone gain level can be adjusted using the Option menu settings. There is also a microphone mute setting which you can switch on and off during a call, maybe this is in the off position. Best bet is to download the user manual which gives instructions for both of these settings. I can pm you a pdf copy if you want. Defender 90XS SW
16th Feb 2017 12:20pm |
Thanks again for the reply, I will check out the user manual, and adjust accordingly.
16th Feb 2017 12:27pm |
