Home > Td5 > Fitting a td5 discovery transferbox into my 90 |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
I have purchased a 41D disco box without the speedo drive. I have been told that I may need to use shims where the output housing is mated against the box? anyone needed to do this?
15th Feb 2017 2:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
what goes in that top hole then? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th Feb 2017 4:59pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
^^^ Nothing. the disco2 gets it ground speed off of the ABS sensors.
I recently swapped the t/box over on my 110 to get rid of an annoying whine. the later box I got was an ex disco2 model with no dofflock or rear hole for the speedo transducer, so after a few emails with Dave Ashcroft (he was very helpful... I'll post his reply up here later when I get home if anyone's interested), I swapped over the front piece to give me my difflock back (I also changed the pinion bearing and put a new seal in and a new drive flange... which is now leaking...typical LR) Rear assy needed swapping over. I asked Dave about the shim business; he suggested to re-use the shims that came off of the original setup (mine didn't have any in anyway) and hope that the bearing doesn't end up too tight (or loose) Anyway, a few thousand miles on and all seems OK. |
15th Feb 2017 5:13pm |
so its a blind hole then?
i have used D2 boxes and plumbed straight into them for speedo Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
15th Feb 2017 5:32pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
You will also need to transfer the hi lo switch housing from your current t box to the new old 1.222 t box.
it's a simple straight exchange. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
16th Feb 2017 1:49am |
Yessir 'tis |
16th Feb 2017 8:39am |
