Home > Technical > Worrying knocking and juddering .... please help
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
Hi all
Driving to work this morning my 1989 defender started making a strange knocking and juddering when coming to a halt. The noise seems to be coming from underneath but not the engine.
She changes gear fine and pulls away without any problem.
Just does it when coming to a halt. Any ideas?
Many thanks
Post #598766 3rd Feb 2017 9:11am
Balvaig
I would start by checking for a damaged brake pad or loose calliper, particularly if your clutch was depressed and you were braking at the time. You can check by stopping in neutral. If it judders then it would seem less likely to be transmission.
Post #598769 3rd Feb 2017 9:35am
It might be worth checking the handbrake, since if this is either adjusted too tight, or if a return spring has failed, this can cause similar symptoms. TDCis are notorious for this.
It might at least be somewhere to start looking.
Post #598770 3rd Feb 2017 9:37am
JamesF
Thanks guys just about to have a look. Seems somewhat intermittent. It happened
once on the journey home but still it must be something amiss.
Post #599072 4th Feb 2017 4:24pm
I'd be inclined to think the same as Blackwolf too. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #599076 4th Feb 2017 5:00pm
g-mack
agreed, handbrake drum Thumbs Up My 109 thread
my youtube channel
Post #599078 4th Feb 2017 5:16pm
JamesF
I turned the handbrake adjuster back a tad and that seems to have done the trick.
She still stays still on an incline to.
Thanks again for the help
Post #599244 5th Feb 2017 3:15pm
Result. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #599248 5th Feb 2017 3:21pm
JamesF
ARRRRGHHH Thought I had fixed it.
Did it again today. Makes no difference if it is in or out of gear.
Seems to carry on for a bit even when stationary. I tried putting it back into 1st gear and it stopped.
Any more ideas folks?
Post #600065 8th Feb 2017 12:19pm
JWL
Mine went through a phase of doing it, I know it sounds corny but do you park with the handbrake on? I had for a while and it was doing it, not using the handbrake (trusty brake mk1 at home in the form of a wooden block) and just park in gear, the rattling/knocking has stopped.
I've put it down to I'm going to have to strip the brake drum out, regrease and put it back together. It's probably full of crud and when warm hasn't completely released away from the drum and at slow speeds it's just close enough to drag.
Post #600132 8th Feb 2017 5:58pm
JWL
Whoops, big fingers, wrong glasses and small phone screen resulting in a double post!
Post #600133 8th Feb 2017 5:59pm
steve E
Wales
I had exact same thing and it was hand brake drum.
Only happened once car was warm and driven for a while.
They told me the pads in the drum were warped and were replaced.
Post #600198 8th Feb 2017 9:39pm
JamesF
Thanks guys. The handbrake still looks favourite. Mine only does it after she has been driven for at least half an hour.I might just release the handbrake off completely and try again then.
Thank again
Post #600294 9th Feb 2017 9:26am
jst
it sounds like the shoes heating up (in the drum brake) over the half period causing the problem to me.
which could be its adjusted too tight or the return shoe springs are broken/worn not working as should be. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #600309 9th Feb 2017 11:11am
