Home > Technical > Worrying knocking and juddering .... please help |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
I would start by checking for a damaged brake pad or loose calliper, particularly if your clutch was depressed and you were braking at the time. You can check by stopping in neutral. If it judders then it would seem less likely to be transmission.
3rd Feb 2017 9:35am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16884 |
It might be worth checking the handbrake, since if this is either adjusted too tight, or if a return spring has failed, this can cause similar symptoms. TDCis are notorious for this.
It might at least be somewhere to start looking. |
3rd Feb 2017 9:37am |
JamesF Member Since: 10 Nov 2016 Location: Hitchin Posts: 71 |
Thanks guys just about to have a look. Seems somewhat intermittent. It happened
once on the journey home but still it must be something amiss. |
4th Feb 2017 4:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
I'd be inclined to think the same as Blackwolf too. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
4th Feb 2017 5:00pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
agreed, handbrake drum My 109 thread
my youtube channel |
4th Feb 2017 5:16pm |
I turned the handbrake adjuster back a tad and that seems to have done the trick.
She still stays still on an incline to. Thanks again for the help |
5th Feb 2017 3:15pm |
Result. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
5th Feb 2017 3:21pm |
ARRRRGHHH Thought I had fixed it.
Did it again today. Makes no difference if it is in or out of gear. Seems to carry on for a bit even when stationary. I tried putting it back into 1st gear and it stopped. Any more ideas folks? |
8th Feb 2017 12:19pm |
Mine went through a phase of doing it, I know it sounds corny but do you park with the handbrake on? I had for a while and it was doing it, not using the handbrake (trusty brake mk1 at home in the form of a wooden block) and just park in gear, the rattling/knocking has stopped.
I've put it down to I'm going to have to strip the brake drum out, regrease and put it back together. It's probably full of crud and when warm hasn't completely released away from the drum and at slow speeds it's just close enough to drag. |
8th Feb 2017 5:58pm |
Whoops, big fingers, wrong glasses and small phone screen resulting in a double post!
8th Feb 2017 5:59pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
I had exact same thing and it was hand brake drum.
Only happened once car was warm and driven for a while. They told me the pads in the drum were warped and were replaced. |
8th Feb 2017 9:39pm |
Thanks guys. The handbrake still looks favourite. Mine only does it after she has been driven for at least half an hour.I might just release the handbrake off completely and try again then.
Thank again |
9th Feb 2017 9:26am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
it sounds like the shoes heating up (in the drum brake) over the half period causing the problem to me.
which could be its adjusted too tight or the return shoe springs are broken/worn not working as should be. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Feb 2017 11:11am |
